My 2006 GTS (250) has a problem with the ignition switch.
In the "on" position I can "wiggle" the key a little bit during which the power circuit will disengage.
So in other words, when I put in the key and turn it clock wise to the on position I can move it like few degrees further on which the power goes "out".
A few degrees before the "on" position there is also no power (that's the way it supposed to be of course)
But on my Vespa this result in he following:
When I turn the key in on there is no power, I then have to wiggle the key a little bit, turn it a few degrees past "on" then back and forth to finally have "ignition".
Any one in here knows of this problem..?? and better yet a solution..??
Is this the mechanical part of the lock or the electric switch on the back of the lock..??
I don't mind getting a new part but I rather have a clue up front to which one is the suspect..??
