strange problem just arose.
My headlamp is no longer working and the high-beam indicator stays on at all times?? (headlamp is good).
I checked the diagram here:
http://www.scooterhelp.com/electrics/wiring/VSX1T.USA.after.pdf
after checking the harness from front to back. no cuts, shorts, nothing. It looks like it may be a ground issue.
That diagram shows two ground points (center diagram slightly below and to the right of the "junction block under horncast").
Are there some frame ground points I am missing? There's one at the stator (black) rectifier (black), and???
I see no other ground point other than on the speedo which looks to me like there should be another frame ground point.
Anyone know where else there might be another ground point?
comments? point, laughing?
