Removing centre stand
Vespa LX 125
Mon Apr 21, 2014 7:53 am quote
Hi all
One of the next jobs on my list now that I've done the clock battery is to remove the centre stand to give it a good clean up and grease.
Any tips on this? Is it just the one long bolt through it from what u could see?
Spring or springs?
I recently built a trampoline for the garden so I think the tool for fitting the springs on that may come in handy...
Any help would be great
Mon Apr 21, 2014 8:45 am quote
The bolt passes through a sleeve that goes through the cases. There are two o-rings that seal the grease between the case and the sleeve.
Ideally you want the stand to be bolted tight to the sleeve and for the sleeve to pivot in the case. From the factory they didn't lube them well and often the bolt is pivoting in the sleeve.
Get new o-rings if you can. take it all apart, put it back together with way too much waterproof grease, wipe off the excess that oozes out.
64 Benelli 50cc, Vespa GTS 125
Mon Apr 21, 2014 8:58 am quote
Photograph the spring arrangement...it is impossible to get them on securely if it is not correctly set up. Also, make sure your scooter is firmly situated/ anchored when you are re-installing springs- it will require a significant pulling force. Dan
Vespa LX 125
Mon Apr 21, 2014 9:01 am quote
Ok... Thanks for the tips so far, I think I'll get a new bolt etc too given that it may need some persuasion to come out!
I'm kind of stuck on securing the bike while I work on it though
Mon Apr 21, 2014 9:06 am quote
Canyon dancers, long straps, and tent stakes. Though that means you are working in the dirt....
You could lean it against a wall with the front wheel pinned between sacks of fertilizer or similar.
Peugeot Citystar 200i, Vespa PX 200
Mon Apr 21, 2014 6:33 pm quote
There's a trick that involves a Phillips head screw driver.
Vespa LX 150ie 3V centre stand
The centre stand has two springs -- inner and outer.
Mon Apr 21, 2014 6:45 pm quote
I've tried the Philips screwdriver trick - if it slips it's bloody (literally) dodgy.
Not having a bespoke spring puller, I use a large (19mm, pretty much its only use) ring spanner ('wrench') with a beefy cable-tie through the ring. This can be used with excellent leverage, and bugger-all can slip.
Mon Apr 21, 2014 6:50 pm quote
Here's an exploded view of the centre stand assembly.
http://www.easyparts.nl/showdrawing/10510/93616/222A/0-4019-1-m425-m1557-m1559-m10510-s10521-d93616/Stand_s.html
Service manual only hints at the possibility of removal. Suppose they take it for granted that we all know the procedure.
Here's the nut referred to in the service manual.
Vespa LX 125
Mon Apr 21, 2014 10:08 pm quote
Thanks for the replies
Still need to think of the best way to secure the bike while I do it
px 200, lxv 125
Tue Apr 22, 2014 4:14 am quote
this is on my to do list.
Im sure I read somewhere that you load the springs with washers (or 2p pieces) while its on the stand and remove keeping the spring pre loaded.
I'm using sand bags to stabelise the scoot.
Tue Apr 22, 2014 4:26 am quote
On using washers or coppers.
http://modernvespa.com/forum/topic108644
jimc wrote:
Sadly, coins aren't easy to use on twin concentric springs. A big eff-off pulling device is required.
Vespa LX 125
Tue Apr 22, 2014 8:30 am quote
Got down and had a closer look earlier, it seems the exhaust would be in the way of fully removing the long bolt ?? I can see the two springs so I understand how that's set up.
On the subject of cleaning the actual stand up, what can I use to make it look a lot nicer? Mines pretty rough in terms of its colour
Cheers all
Tue Apr 22, 2014 3:45 pm quote
New paint? Sandblast and powder coat? Rattle can?
Or buy a new one for 32.42 euro.
Vespa LX 125
Tue May 13, 2014 10:53 am quote
Does the exhaust have to come off to get the bolt out?
Cheers
1975 Vespa GTR 125, 1976 Vespa V90 (Resto), 2001 Vespa ET4 125 (Sold), 2009 Vespa GTS300 Super
Tue May 13, 2014 11:35 am quote
You definitely need a technique to reinstall the springs because having done it on my GTS its blooming hard work. For refurbing the stand, I clean off the main rust with a wire brush cup in a drill, then give a coat or two of spray black Hammerite smooth. It's not perfect but it'll last a year or so. I also tried the VHT spray black epoxy paint on my exhaust bracket, which seemed to go on well, but not had it on long enough to know how it fairs longer term.
Vespa LX 125
Tue May 13, 2014 11:45 am quote
Thanks, I hope to use a spring puller I have to do the springs, will the bolt come out with the exhaust on?
Tue May 13, 2014 11:54 am quote
Not sure as I've not owned an LX, but judging from the photos above, it doesn't look like the bolt will extract fully with the exhaust in place...
Vespa LX 125
Wed May 14, 2014 2:54 am quote
I feared that
Vespa LX 125
Wed May 14, 2014 9:57 pm quote
For now I've loosened the nut a tad and gave it a good squirt with wd40 and on the springs. Left overnight and now it seems to be retracting fine.
I'll probably remove it when I next have the exhaust off
Lx 50 4T, GTS 250, S 150 (Missing in KS), Something Chinese, GT 200 (sold)
Thu May 15, 2014 11:39 am quote
It is clear to me that you are investinng a lot of thought and time in your endevour. I would clean the spring with a wire brush and engine cleaner before re-painting them. Do the same to the stand before repainting it. The internal components that have been mentioned may be replaced for a reasonable price. The likelyhood of your finding that these are all rusted out is very high. You may be better off replacing them. Not sure if they have cage bearings or not. Use liberal amounts of grease.
Vespa LX 125
Thu May 15, 2014 11:55 am quote
The springs and O rings are cheap enough, also the bolt and nut are too.
I was thinking of Shot blasting the stand before painting it
Vespa GTS 125
Mon Oct 12, 2020 1:12 am quote
The pin for my centre stand has siezed up and i cannot get it out.
Any tips for removing it?
Ive managed to take the nut off, but the head of the pin snapped off after a struggle trying to remove it.
Maybe theres another part i can remove that holds the pin? As a last resort.
Thanks!
Wed Oct 14, 2020 4:53 pm quote
Thanks!
Like all lessons in life. Lube, pressure and angle of approach.
Realistically, though, you’re going to need heat, lube, a big long punch and a BFH
good luck.
-g
Wed Oct 14, 2020 5:02 pm quote
Thanks!
good luck.
-g
I get the heat, lube, and BF, but what's the H?
Reminds me of when I was a bicycle mechanic (full time, that is).
We had what we called a Huffy Adjustment Tool. It was a large hammer.
Fun times...
Wed Oct 14, 2020 5:19 pm quote
greasy125 wrote:
....and a BFH
Ooh, interested now. I have a couple of those inherited from my dad. I'm guessing they'd seen their share of whaling. I've left the 16 pound maul home on the farm for my own protection.
Best friend had a penchant for collecting the "BF" category of tools... big ass adjustable wrench and screwdriver you'd need two hands for come to mind.
Sorry for the digression. Carry on!
2010 S50 Modified "Punkin"; 2003 ET4 150 "ISO"
Wed Oct 14, 2020 5:23 pm quote
Greetings:
H stands for the last word in your post before Fun Times.
As in ... Big... Freakin' (sorry G, keeping this PG) HAMMER!
150 Sprint Veloce,Vespa GTS 300
Fri Oct 16, 2020 12:45 pm quote
When I took mine of to have it powder coated, getting the springs off was fairly easy, getting the bloody things back on was a right pain! I tried fitting washers between the springs to ease off the spring, but I didn't manage to put enough on, and it made the job harder to remove the spring, but it came away in the end.
I bought one of these through ebay
but even using this was a bit of a struggle, I had to give myself enough room to pull the hook and stretch the springs enough to put over the small "bar" .. but boy, was it a pain!!
Graham
2018 Vespa 300 GTS Touring
Fri Oct 16, 2020 1:02 pm quote
I found this video to be useful to getting the spring back on.
https://www.youtube.com/watch?v=uV2302RejyI
Sat Oct 17, 2020 12:43 am quote
oh, and here's the pro tip: besides removing the exhaust, tie off the front and put the rear wheel up on a block of wood so you can put the centerstand up. the springs go on much easier that way. and don't be stingy with the lube. slather everything up real good.
-g
Missouri Loves Company Rally   vespa scooterwest scooter west Motorsport Scooters   Cool Ass scooter seat cover
[ Time: 0.1698s ][ Queries: 25 (0.0251s) ][ Debug on ]
