I have seen some threads and searched Google but haven't found the info I need.
I have a Vespa 300 GTS and would like to install these spoked rims from an MP3
(like the ones here: http://goo.gl/0qcR9M , http://goo.gl/wn5Msf )
I have heard that two from MP3 rims will work. On the 300 GTS, the front is a direct bolt on where the rear requires slight machining/ modification to make it fit.
Can someone tell me what the exact modification should be for the rear MP3 wheel to bolt on? Anyone done it with both front and rear on a 300 GTS can post photo?
Thanks!
