Vespa 90 with a polini 115...19 mm carb ...DR 22/63 (2.86)up gear kit...PK clutch cover..Brand new Pk clutch. leo vince pipe
new pressure plate(the one with bearings)..new brass plunger..new wire clip.
plates soaked in oil
New outer and inner cable
The scoot still pulls foward with clutch pulled in.
Sits still at idle and then pulls away if I rev it higher whilst lever pulled in
I tightened the cable until the kick start would not engage and then backed off I until it did.
Did all sorts of adjusting
No joy soooo pulled the clutch out
I used a home made compressor and the plates etc all separate nicely. Then I tried each one in the basket and it doesn't catch on the basket at all...they are best described as snug..not loose however
Could this be the problem ..ie should I file down each finger a bit...how much gap should there be.?
What else can I check..ie what about the brass bush bit inside the basket... if that wears down would it bind on the xmas tree
what say ye
