So I didn't like the idea of spending $200 or more on belt replacement tools. One day while at work, I measured the clutch access holes and used the lathe & mill to make a clutch tool.
I was thinking that I could make the tools in a way that someone without access to a lathe and mill could make them.
Yes I Know that a tool can be made with a U bolt. If you knew the distance between the access holes, you would agree that it would take a large U bolt and quite a bit of bending.
First I'm going to show you my clutch tool. Then I'm going to show you how to make a clutch and outer drive pulley tool for less than $15.
Please DON'T reply to this thread until I'm finished(I'll let you know).
