Vespa GS150
Post Reply    Forum -> Project Reports 12Next
Vespa GS150, Messerschmitt GS150
Mon Jan 11, 2016 9:41 pm quote
I am currently putting together a GS150 engine with the best tuned parts on the market at this moment in time.
Remade Scooter-Center barrel & Gran Sport piston, the barrel has been matched to the Series - Pro manifold with Dellorto 24 PHBL carburettor, CNC cylinder Head, Pinasco 12v Ignition, Kingwelle Crankshaft & a specially designed GS tuned exhaust.
Bigger GS piston.
The casings have been stripped and will be mirror polished, 3-4 weeks before these are ready.
Honda elite
Tue Jan 12, 2016 4:31 pm quote
as a fellow GS 150 owner - looking forward to the project/updates!
Wed Jan 13, 2016 8:35 am quote
This is the new exhaust for tuned GS150 engine, pictured with a standard exhaust so you can see the difference.
vespa 125 vnb1t
Wed Jan 13, 2016 12:30 pm quote
just a heads up
i just fitted a pinasco fly-tec ignition on my tuning project a vnl1 engine
not impressed at all
there's nothing in the instruction documents that came with the kit on fitting any kind of spacer and there's no key to lock the flywheel to tighten it
i had to do a fair bit of drum sanding with a dremel to make it fit the case
there wasn't enough clearance between the raised lip for the crank seal and the stator plate and not enough clearance for one of the screws
make sure you check it properly before you tighten the stator plate screws else you may break your new base plate
looking forward to seeing yours finished
Wed Jan 13, 2016 1:05 pm quote
The VN scooter must be slightly different. I have the Vespatronic on my other GS & its so poorly made, expensive & not well made. Pinasco is far superior to the Vespatronic & an easy fit for the GS. I know a few GS owners with the Pinasco and they couldn't be happier.
GTS250
Thu Jan 21, 2016 12:33 am quote
another great project to follow - where do you find all these GS's?
Thu Jan 21, 2016 1:55 am quote
a few years ago I was able to pick up around 7/8 GS projects for very little money, kept a few for myself and sold a few on, which paid for the ones I kept. unfortunately, the contact I had has not been able to source as many as he used to & the ones he did find more than doubled in price, but I still keep looking.
hope to have a few more pictures to post shortly, but at the moment I am relying on few others to do the things I can't.
Thu Jan 21, 2016 8:00 am quote
The Billet cylinder head with 'O'ring.
Sun Feb 21, 2016 8:19 am quote
Vespa GS crank
Vespa GS crank
This crank allows you to use the PX clutch and the seals are on the outside of the crank case which makes things a lot easier, if a seal goes.
Sun Feb 21, 2016 8:24 am quote
Vespa GS150 twin pipe sports exhaust
Also got this exhaust, again a new designed exhaust for the GS which should add a few more hp.
Sun Feb 21, 2016 1:21 pm quote
I was going to suggest you contact Megadella for an exhaust... but I see you already did! No joy there I take it from the lack of reply?
Sun Feb 21, 2016 1:39 pm quote
Its not the Megadella exhaust, its by Vespazio (Luca). I believe there will be a few other GS exhaust on the market shortly.
Fri Feb 26, 2016 10:53 am quote
A glimpse of whats to come.
Vespa GS150
Vespa GS polished casings
74 50s x3 78 P200 84 Cosa PK50XL2 58 AllState 68 Sprint 80 50special '66(?) Super125
Wed Mar 16, 2016 4:53 pm quote
Holy Smoke, Gary, those are beautiful!!! You should have no problem keeping that motor clean. Can't wait to see it together w/ the other goodies.
And you get a nice incidental benefit:
you never have track down a mirror when you feel like shooting selfies
Wed Mar 16, 2016 11:27 pm quote
geeez those cases look good
P125X, P200E
Mon Mar 21, 2016 3:09 pm quote
Wow, I've never seen cases polished like that... how did you do it?
Tue Mar 22, 2016 12:56 am quote
I first used a wire brush on a grinder and then sent them off to be professionally polished. You can get a very good finish yourself, just with a bit of elbow grease.
This was a set of PX casings I had done a few years ago.
Vespa Polished Engine Casings
Vespa GT200L
Wed Mar 23, 2016 1:17 pm quote
Looking sweeet
beautiful.
P125X, P200E
Thu Mar 24, 2016 9:48 am quote
I had no idea cases could be polished like that. That's something I may try one day... when I'm REALLY, REALLY bored.
Thanks for the response. Yours look great!
Thu Mar 24, 2016 11:50 am quote
This is what you can achieve with a grinder & a wire brush attachment. If you keep on top of the casings using carburettor/brake cleaner then they will stay like this for a long time.
Vespa PX casings
Wed Apr 27, 2016 12:30 pm quote
Vespa GS chrome & polish
Sat Apr 30, 2016 9:47 am quote
great so far
2015 Vespa GTS 300
Tue May 17, 2016 5:34 am quote
Vespa GS150
Tue May 17, 2016 5:45 am quote
MNRider2007 ?
2015 Vespa GTS 300
Tue May 17, 2016 12:01 pm quote
I really like the look of those polished parts. When I quoted the article above I forgot to add a comment.
Sat Jun 25, 2016 1:07 am quote
Vespa GS150 engine build
Vespa GS150 engine
Vespa GS150 paint/prep
This project has been really slow, through no fault of the people involved, engine has had its teething problems with the new type of crank amongst other things and the paint colour/design has been a difficult decision, which is my fault. As you can see not in bad condition considering its nearly 60 years old.
I should have a lot more pictures and progress on this build in the next two weeks, sent more stuff to the chrome/polishers and with a little luck engine should be finished. Paint is probably 4 weeks away due to holidays.
Wed Jul 06, 2016 8:08 am quote
Vespa GS150 chrome & polish engine
Vespa GS150 chrome & polished engine
There will be paint added to the engine cowl, flywheel, exhaust & other parts, just not decided the colour yet
Sun Jul 10, 2016 8:18 am quote
I have done a bit more work on the exhaust.
Vespa GS150 Exhaust
Honda elite
Sun Jul 10, 2016 7:02 pm quote
nice exhaust deflector(s)! Can you show a photo of the twin exhaust pipes where they exit of the box? Was the exhaust a custom job?
Mon Jul 11, 2016 2:06 am quote
its a standard exhaust with twin pipes where I have added the second engine side tailpipe, the two deflectors are original GS accessories. Click on the image & it should play a small video.
Vespa GS150 twin exhaust
Mon Jul 11, 2016 9:02 am quote
Vespa GS150 engine with twin exhaust
Honda elite
Mon Jul 11, 2016 9:46 am quote
wow that is very nice. I would like one of those deflectors for my VS5.
Wed Jul 27, 2016 2:15 am quote
Vespa GS150 is now in paint, waiting on its secondary colour on the panels, mudguard & headset.
Also built a engine stand to help run in the engine.
Fri Jul 29, 2016 12:26 pm quote
Vespa GS150
Vespa GS150
Vespa GS150
Vespa GS150
Vespa GS150
Vespa GS150
Vespa GS150 auxiliary fuel tank
Vespa GS150
Honda elite
Fri Jul 29, 2016 3:31 pm quote
looking great are you doing the paint yourself?
Sat Jul 30, 2016 1:44 am quote
no, couldn't possibly get it to this standard. this is in fact the painters first ever scooter & he has done a bloody great job of it. a few minor issues, but they were my fault not his & I am planning on using him again.
Vespa T5 - GTS250 - HEAT
Sat Jul 30, 2016 10:39 am quote
Painters
Can always do with a good painter Gary. Is he expensive?
Sun Jul 31, 2016 12:24 am quote
No, very good price & quick turnaround.
Wed Aug 03, 2016 2:14 am quote
The build process begins & all the shite jobs are done bar the front end.
Vespa GS150
Vespa GS150
Vespa GS150
Vespa GS150
Vespa GS150
engine up & running, great compression.
Vespa GS150
Vespa GS150
Vespa GS150
Vespa GS150
Vespa GS150
Vespa GS150
Vespa GS150
Vespa GS150
Vespa GS150
although the scooter is nearly finished, Ive still got a lot to do, the exhaust needs looked at, either re-chromed or ceramic coated with chrome pipes. theres also one or two other decisions to make, but I need to get it on the road, mot & other UK paperwork sorted.
GTS250
Wed Aug 03, 2016 11:10 am quote
Looking forward to seeing this competed - looks like it will be a stunner
Land of 10,000 Scoots Rally   vespa scooterwest scooter west Motorsport Scooters   Scooter Parts Company
[ Time: 0.1869s ][ Queries: 25 (0.0514s) ][ Debug on ]
