I did search, and already dbl checked the spark plug wire seating...
2010 GTS 300 Super
1,100 on the odo.
I know it's definitely electrical related, and not fuel / mechanical related issue. The engine cuts out just a split second while riding, and the "check engine light" and the "red code led light" comes on, and turns off after about two seconds. And this usually happens when I go over a bump or gets jarred, but not always - sometimes it just cuts out without any other warning...
Is there anything else I should look into / replace for this symptom, please? It seems like others have similar "GTS engine cutting out issues", but didn't see others with the same "lights" issue w/ engine cutting out.
Thank you!
