Piaggio Mp3 - Thermometer problem (It says LO)
Piaggio Mp3 2009
Sat Jul 16, 2016 2:34 am quote
Hi all, I just bought Piaggio Mp3 400 2009 from second hand and I still have problem with thermometer.
On LCD it says LO instead temterature.
Could you help me with this?
Can you tell me, where is situated the Thermometer on scooter? It helps me.
I just add photo of it.
Thanks a lot for help guys.
LO on LCD display.
Sat Jul 16, 2016 3:30 am quote
your low on coolant.
Sat Jul 16, 2016 3:55 am quote
I had no idea this warning existed!
Cool....
Piaggio Mp3 2009
Sat Jul 16, 2016 4:50 am quote
Not sure, yesterday I tried to full it, did not help :/ but thanks for help
2016 MP3/500 Sport ABS, 2009 MP3/250, 2012 GTS Super 300ie
Sat Jul 16, 2016 5:18 am quote
Be careful with that, not having adequate coolant can cost you a engine.
There is a process to follow to get the Air out, do your research.
If its been two years, you need to flush and re-fill with the Red/Pink AGIP Coolant.
Keith,
Marietta, GA
Sat Jul 16, 2016 5:53 am quote
I might be mistaken on the coolant it could be the outside temp is below or close to freezing.
Sat Jul 16, 2016 6:07 am quote
Could be, but for some reason I recall it saying "ICE" when it is cold out.
Sat Jul 16, 2016 6:08 am quote
That, and the weather in Slovakia right now is nowhere near freezing, so if that's a pic of a freshly purchased scooter, probably not an ice warning.
None at present
Sat Jul 16, 2016 7:41 am quote
I thought the scooter was being polite and greeting you. L O (hello) Don't worry I'll get my coat on the way out
Sat Jul 16, 2016 8:35 am quote
That's not happening here in Atlanta...
Time to read the Manual.
I have never seen LO before, that was a knew one on me.
I just searched for LO in the User Shop Manuals. Nothing...
2019 MP3 500hpe Sport
Sat Jul 16, 2016 12:45 pm quote
it is 07 degrees. it is just upside down.
i did a google search really quickly and came back with nothing other than another post on here from 2009 or 10.
Sat Jul 16, 2016 2:10 pm quote
Ok, I can accept that being upside down, but what about the other digits on the same LCD Panel, they aren't upside down. I spent an hour or so on this, it had me so curious I gave up looking.
Keith,
Marietta, GA
Piaggio Mp3 2009
Sat Jul 16, 2016 10:06 pm quote
There was 35 degree and it said LO
I just did not try to take the air out of engine and intercooler system, but as far as I know, it is done by itselft (automatically)
Or if not helps, try to change all watter there.
Piaggio Mp3 2009
Sat Jul 16, 2016 10:10 pm quote
Ehmm, OK hope so then I go to the garage and appologize and ask for temperature info you know it says all the time when it is running
Thanks for idea
Piaggio Mp3 2009
Sat Jul 16, 2016 10:11 pm quote
Thanks for time, I tried to search it in manuals, nothing
2009 MP3 400
Mon Jul 18, 2016 6:49 am quote
You do need to burp it manually. It's covered in the service manual (available via link in the wiki) and quite easy.
Scarabeo 500GT(hers), `07 250 MP3, `09 400 MP3
Tue Jul 19, 2016 8:56 pm quote
When I was riding my 400 MP3 in high temp conditions the temp gauge went from reading 123F to HI when the temp I assume hit 124F. So at least on the high side the temp gauge only reads accurately to a certain point. If it was really cold in Slovakia maybe that's why it read LO.
MP3 500ie
Wed Sep 09, 2020 1:03 pm quote
"LO"?????
my 2009 mp3 500 shows "LO" where it usually reads the outside ambient temp. any idea why? i never saw an answer to the original post...
Piaggio MP3 500
Thu Sep 10, 2020 7:07 am quote
For 2009, you only have 6900 miles, it means that your mileage is LO, you need to get out and ride more.
I suspect it's a problem with the temperature sensor or its connections. The sensor is located under the leg shield, and it can get covered with road debris and dirt and water, and the connections can go bad. Find it, clean it off and grease the connections with some dielectric grease, and it will probably start working again.
Gilera Fuoco 500ie
Thu Sep 10, 2020 12:47 pm quote
coollant or air in the system or temp sensor kaputt
50cc Beo, BigBeo
Thu Sep 10, 2020 6:56 pm quote
This temp is read not from head temp sensor, but from riders' right knee. So no coolant there (unless spilled on their pants).
Gilera Fuoco
Fri Sep 11, 2020 2:37 am quote
Re: "LO"?????
Don't look for logic in Piaggio's actions
For example, how would you like to sound 5 beeps when there is a pressure problem in the tilt lock system? It doesn't make any sense, but it exists ...
Based on my complete lack of experience with Italian technique, I agree with Squeazel's idea, and I assume that the wire to the ambient temperature sensor is open or short in this line.
50cc Beo, BigBeo
Fri Sep 11, 2020 8:46 am quote
If you ever had a will to read manual, 5 beeps would make sense for you
Gilera Fuoco
Fri Sep 11, 2020 8:49 am quote
In the manual can describe any crazy thing to cover ass...
50cc Beo, BigBeo
Fri Sep 11, 2020 9:15 am quote
Those 5 beeps are totally fine for anyone around the world, what's wrong with them for you?
Fri Sep 11, 2020 2:48 pm quote
Mine does that when the outside temp is below freezing. It is letting you know it is cold enough for water on the road to freeze.
Gilera Fuoco
Fri Sep 11, 2020 10:31 pm quote
This is more believable, than coolant volume...
MP3 500ie
Thu Sep 17, 2020 2:56 pm quote
Well I filled up the coolant and the reading did not go away also the outside temperature is around 80 degrees Fahrenheit so it's not an outside temperature warning from the temperature being too low so this is really got my head spinning I called dealerships and even they can't give me an answer. This is really weird and if anyone could give me an answer on why it's reading "LO" I would really appreciate it because at this point I'm scared to keep riding it without knowing what the issue is
Thu Sep 17, 2020 3:21 pm quote
Don't be scared of riding it. It can only be a faulty sensor, or more likely the connection to it. This is only the ambient temperature reading after all! That's of big consequence to the engine, thought it might take it into account to in its air-mass calculations.
50cc Beo, BigBeo
Thu Sep 17, 2020 8:31 pm quote
I guess ECU takes into account the other sensor, which is located in throttle body. Simply because it is more accurate to real temp of intake air.
Cross Egypt Challenge - A 2400km ride throughout Egypt   vespa scooterwest scooter west Motorsport Scooters   AF1 Racing Vespa Austin
[ Time: 0.1766s ][ Queries: 27 (0.0451s) ][ Debug on ]
