Question reg. crankshaft oil seal Vespa GS160 (pics)
Vespa Grand Sport 160 GS/4 MK 1963 Vespa PX200E 1993 + LML StarDeluxe 150 Previous owned: Lambretta: TV175 S2 Li150 S3 Schoolmaster Edition Li 150 S1
Wed Sep 28, 2016 9:39 am quote
Hi Friends
I am changing all the bearings and oil seals on my Vespa GS160 (1963).
The parts are from SIP scootershop (complete bearing and oil seal set).
My question is regarding the crankshaft bearing and oilseal.
First i fitted both the oilseal and bearing from the clutch side but was told by SIP scooters that the correct way is: bearing from clutch side and oil seal from crankshaft side. So i ordered a new oil seal and then did it the way SIP said was the correct way.
BUT BUT I just think that the SIP way looks wrong, the bearing is correct but the oil seal looks way off. It can only fit with the metal side thise way. Please see the way i fittet it first (last picture).
Please see the pictures and let me hear what you think.
This was my first fit before SIP corrected me. Both the oilseal and bearing mounted from the clutch side.
Hope you can help me out
Cheers
Kasper Winding
Denmark
Wed Sep 28, 2016 10:31 am quote
your first way was correct
Wed Sep 28, 2016 10:51 am quote
Damn
Wed Sep 28, 2016 10:52 am quote
What picture is the correct way?
Wed Sep 28, 2016 11:05 am quote
Found this on the net
And original factory manual from scooterhelp
So far i can see the both pictures are done the SIP way, correct ?
Wed Sep 28, 2016 3:49 pm quote
http://oopsclunkthud.com/Vespa_service_manual/Pages/217.html
figure 4
This if from the service manual not the parts.
Wed Sep 28, 2016 4:00 pm quote
you had it right in this picture:
Note: the lip with the spring around it should face the crank case so they hold the pressure during the transfer process.
Wed Sep 28, 2016 10:40 pm quote
Thanks ALOT oopsclunkthud
I also thought that my first try looked correct
Think that Martin Silberhorn from SIP scooters owes me a oilseal and perhaps a discount code for all the trouble
Thu Sep 29, 2016 2:43 am quote
Hi oopsclunkthud
Now I am confused?
Now SIPS are telling me that the last try is correct, i just need to flip the oilseal. (bearing in from clutch side and oilseal from crank side, just flipped)
Problem is that it does not fit if I flip/invert it.
Before I ruin more oil seals I need to be sure.
Personelly I think that oopsclunkthud's way is the correct way
Message from SIP Scooters:
Oliver just told me you mounted the oil seal the wrong way round. Correct side, but inverted.
Martin Silberhorn, M.A.
Senior Key Account Management
SIP Scootershop GmbH
Marie-Curie-Str. 4
D-86899 Landsberg am Lech
Germany[/list]
Thu Sep 29, 2016 2:46 am quote
This MUST be the correct way.
The oil seal and bearing is mounted in from clutch side. (first try)
You can not mount oilseal from crank side with metal facing clutch side.
Thu Sep 29, 2016 3:13 am quote
GS160, V50R
Thu Sep 29, 2016 4:10 am quote
The two pictures, scooterhelp/oopsclunkthud, differ and the scooterhelp pic has been up to discussion before as being faulty. As oops wrote, the lip/spring side always facing the crankcase.
Thu Sep 29, 2016 4:20 am quote
So what you are saying is this is the correct way? Vespaholic
GS160, V50R
Thu Sep 29, 2016 4:32 am quote
Yes.
Another discussion on the subject:
Vespa SS180 clutch side oil seal Fixed & Re-build pictur
Sat Oct 01, 2016 2:25 am quote
I HTML5'ed your manual
http://online.fliphtml5.com/qtjt/rbak/
Rallies Europe 2016   vespa scooterwest scooter west Motorsport Scooters   Scooter Parts Company
[ Time: 0.2778s ][ Queries: 25 (0.0414s) ][ Debug on ]
