slight problem with the new SIP GTS Speedo
Vespa 300 GTS 14- / Vespa 180 GTR / Mini Cooper S Mk3 / 2002 200 disc / 1978 150 Super / 1963 Lambretta 150li
Fri Nov 18, 2016 9:12 am quote
just an update on the new speedo .. the water temp bars on the left hand side don't seem to work ... checked the wiring etc etc .. fuel gauge bars work fine everything else seems good lights etc .. just the water temp bars now got in touch with SIP and they emailed me with ... and I quote
Hi Simon,
the water temperature is measured over the wiring loom.
Thereīs no connection to the settings, we think thereīs a problem with your bike.
Is there a possibility that you send us a dropbox link with a video what happens?
That would be great.
And please explain the problem in details again, itīs easier to help for us then.
Have a nice day.
Kind regards,
so sent them a picture of the bars not even coming on ... and wait to here what there idea are ...
ive checked the temp sender on the bike ... the cooling fan cuts in when its it getting hot so I cant see how it is a problem with the bike .
now I know theres no temp gauge on the new vespa .... but it still checks its temp because of a warning light on the old speedo face ...
joys of something new ...
just wanted to know if anyone else has one on their ABS GtS and does your temp bars work ok
GTS 300
Fri Nov 18, 2016 11:05 pm quote
Mine works fine. The only issue I have is with the optional temperature sensor, I cant get the spark plug back on with the adapter ring fitted.
Fri Nov 18, 2016 11:35 pm quote
hello mate is yours and ABS 2014 onwards bike ???
GTS 300
Sat Nov 19, 2016 12:26 am quote
2014 non-ABS
Sat Nov 19, 2016 12:47 am quote
mines a 2016 abs ... bike ... but it says nothing in the instruction booklet about the water temp bars on an ABS bike do not work, to be honest this is the only reason I got this because there is no water temp gauge on the new bikes ... and SIP seem to say they do work because the cooling temp is still in the loom or the overheat warning light will not come on ... electric fan comes on all ok
all a bit strange I await to hear what they say ...
250 gts, nitroed zip 69cc " the teenager", 200 now 300 lc zip "all grown up"
Sat Nov 19, 2016 1:05 am quote
Hi
i am not familiar with the ABS version of the gts but if the bike has no temp gauge from the factory then i am certain piaggio have not fitted the temp sender in the cylinder head , this will be the reason there are no bars illuminated whatsoever on the dial.
There will be a temperature switch for the fan but this will be a 3 wire sensor triggering the fan first then at a higher temperature triggering the over heat light.
Look at your cylinder head for a blanking plug.
Cheers Andy
Sat Nov 19, 2016 1:26 am quote
i had a feeling that was going to be the case ... thought there would be a note in the instruction booklet saying the temp bars on the ABS version will not work ...
will have to wire one in one day ...
thanks again
Sat Nov 19, 2016 1:59 am quote
if you don't mind me asking what were your speedo settings for the speedo
Sat Nov 19, 2016 6:38 am quote
no wire required
Hi buddy,
you have missed what i was trying to explain, buy yourself a temp sender unit, undo the blank out of the cylinder head then bolt the sender into the the head, trace the loom wires around that area locate the sender wire (which will be taped up in the loom with the correct spade end attached) attach to the sender unit you have just installed and a voila working temperature gauge
cheers Andy
Sat Nov 19, 2016 6:54 am quote
mate your a star ... I found this water sensor on the head ... cant seem to find any blanking plugs ... unless its under the floor cover ...
Sat Nov 19, 2016 7:04 am quote
and this is the only one I found on a parts web site that fits in the head ... it fits all the range from 2008 - 2016 .... unless I can find the wire colour that goes to the head set ...
all a bit strange ...
will find out what sip say they must have put it on a 16 plate scoot
Sat Nov 19, 2016 7:13 am quote
they have changed the wireing
hi buddy,
that is where there is normally a one spade wire sensor, the two wire explains the two stage switch that i posted in my first explanation.
you will need to buy a thermal housing like this
http://www.ebay.co.uk/itm/CAR-Water-Temp-Temperature-Joint-Pipe-Sensor-Gauge-Radiator-Hose-Adapter-32mm-/401228320012?hash=item5d6b124d0c:g:JZcAAOSwXeJXdiX~
splice it into the return hose under the floor board connect just one wire to the SIP gauge then you are good to go, an easy solution
Cheers Andy.
Sat Nov 19, 2016 8:05 am quote
so its a standard one spade connector and then find the coloured wire that goes to the back of the speedo this is the connector block I have at the back of my unit .. then a wire from the sender to the unit ... I can do that lol lol
going to give that a go over the next coupe of weeks ... my head has blown up lol
thanks again for your help mate I'm not that brill with electrics ...
Sat Nov 19, 2016 8:15 am quote
simples
looks like a piece of piss mate, the second connector block you have on the SIP loom is for a gts 250 / 300 non abs, the sender wire you need to connect will be the only wire with a zero continuity output as there is nothing there, the loose wires are for ancillary optional extras only.
Easy peasy lemon squeezy
Andy.
Sat Nov 19, 2016 1:02 pm quote
sweet .. I may need a bit of advice fella nearer the time
thanks again
Sun Nov 20, 2016 1:40 am quote
morning Andy
I'm going to run this with you ... if I sound like a knobhead then tell me lol
on the older 300 there are three connections into the speedo head on connector B there is the Green/Yellow wire that should be the water temp sender to the gauge in the speedo ..
now stay with me on this one
as there are only two sensors for the water temp a coolant temp and a electric fan switch and as I have the standard temp sender in the head can I pump into the G/Y wire from that and into the wire in the head witch looks likes its there but not connected ..
just a thought ... ???
like I say if am out of it ... then shoot me down lol
Sun Nov 20, 2016 2:01 am quote
go for it
hi buddy,
have a tinker you cannot do any harm as the sensor wires are all - polarity the only + polarity is in the actual display.
so go on have a tinker
Cheers Andy.
Sun Nov 20, 2016 3:33 am quote
found the starting point the engine senor on the head has on two wire coming out of it .... missing the yellow/Green ... but now I need to find the input to the square connector for the speedo unit ... what I might do is to buy the early sip connector and find the coloured wire that is the temp bars ...
all good fun
Sun Nov 20, 2016 7:20 am quote
oh well ive tried every thing possible... just cant find the temp terminal ...
will try another day ... brain has gone into meltdown lol
Vespa gts 300 abs
Thu Jan 12, 2017 1:17 am quote
Hi buddy,
However, after install the speed meter with the Koso speed sensor SA07, all function can be display except the speed cannot be show correctly,the speed up from 20 to 70 in second, when keeping speed at 70 the speed will suddenly drop to 40.
Please advise what I did wrong on the installation process and how to solve it.
Thank you
GTS 125 Lewis Hamilton F1 STYLE
Mon Feb 06, 2017 1:56 pm quote
Speedp
Marioloi wrote:
Hi buddy,
Hi was it easy to get the Kosovo cable up to the speedo I am thinking of drilling a hole in the top of mudguard
Thank you
2016 gts 300 super
Mon Feb 06, 2017 2:02 pm quote
I have a 2016 gts super sport 300 will that Speedo work on her.
Sun Apr 16, 2017 1:13 pm quote
Re speedo
Marioloi wrote:
Hi buddy,
Thank you
hi just fitted one one mine is yours working ok now ?
Sat Feb 03, 2018 8:00 pm quote
SIP retrofit to a GTS 250?
Can the SIP see do designed for the GTS300 adapted to fit a 2006 GTS 250?
Sponsor
Granturismo 218
Sun Feb 04, 2018 9:11 pm quote
They offer it for the 250 as well. It's a different part number, but that might be the wiring harness they include.
150 Sprint Veloce,Vespa GTS 300
Sat Aug 01, 2020 9:57 am quote
I have that exact same problem as you, The sensor ring that goes over the spark plug blocks access tp the spark plug hole on the cylinder, plus the fins get in the way... Good idea, poorly executed, shame on you SIP!
Graham
Cross Egypt Challenge - A 2400km ride throughout Egypt   vespa scooterwest scooter west Motorsport Scooters   Scooter Parts Company
[ Time: 0.1694s ][ Queries: 27 (0.0465s) ][ Debug on ]
