can a genuine piaggio 300cc cylinder fit on vespa gts 125?
vespa GTS super ie 125
Wed Jan 04, 2017 8:26 am quote
Hi guys
??? silly question, but there seems to be a lot of knowledgeable people on this thing, so what to try my luck ...
... can a genuine 200cc (http://www.sip-scootershop.com/en/products/cylinder+kit+piaggio+200cc+_pi843291),
250 cc (http://www.sip-scootershop.com/main/base/Details.aspx?ProductNumber=PI843517)
300cc (http://www.sip-scootershop.com/main/base/Details.aspx?ProductNumber=PI876457)
(website FYI) .... fit on a 2015 UK vespa GTS super ie 125.
Wanna give my new baby a bit more bang for her buck.
This bike is used by another, so not able to do full test etc.
Just wonder if it can be done and how please ... and want other bits can be done to it and if its worth it .... ie, changing the rollers, clutch, exhaust etc.
Thanks in advance everyone
250 gts, nitroed zip 69cc " the teenager", 200 now 300 lc zip "all grown up"
Wed Jan 04, 2017 10:22 am quote
yes and no
hi there,
i have done it
kubler kit is the easiest way, other than that you need to have expert machining knowledge and uber mechanical skills making the crank fit a quaser cylinder in a leader engine.
good luck.
cheers Andy
Sponsor
Granturismo 218
Wed Jan 04, 2017 11:10 am quote
Re: can a genuine piaggio 300cc cylinder fit on vespa gts 12
Assuming you are asking about simply bolting on the parts, without extensively modifying the engine or replacing the crankshaft...
200cc YES
250 cc NO
300cc NO
Depending on what you can get them for in the UK, the best bang for the buck is going to be the complete Malossi 218cc kit, because it bolts right on and addresses the major weakness of the Piaggio engine in terms of making power.
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   Vespa Wasp Neck Scarves   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1298s ][ Queries: 23 (0.0441s) ][ Debug on ]
