BV350 - sticking centre stand
PX150
Tue Jan 10, 2017 6:01 am quote
Anyone else found that the centre stand gets "gunked up" after a while?
I'm waiting for dry weather to get down and give it a clear out, but mine rocks off the centre stand but doesn't then retract fully. I have to give it a nudge with my boot. The spring hasn't broken, I can see that from the right hand side of the bike, but it's got lazier.
BV350
Tue Jan 10, 2017 8:39 am quote
I find mine on the bv350 comes a little loose and rocks side by side more and then doesn't retract so readily!
BV350, Yamaha Zuma 125, Yamaha FZ6, Kymco GrandVista 250
Tue Jan 10, 2017 9:06 am quote
There's a thread on overhauling the center stand: BV350 center stand
I've never had a problem with mine. I put a little grease on it occasionally.
Tue Jan 10, 2017 9:11 am quote
I use White Lithium Grease on mine once a year. Seems to work.
C650GT BV350 GTS300 PX150E
Tue Jan 10, 2017 9:29 am quote
Re: BV350 - sticking centre stand
MelBelle wrote:
...mine rocks off the centre stand but doesn't then retract fully.
When mine started doing that, it turned out that one of the mounting tabs
had broken off. Based on several threads here, that is not an uncommon
problem. You might want to check.
piaggio fly50 4t 2v , honda ruckus x 2
Tue Jan 10, 2017 1:32 pm quote
I have had that happen on a few different scooters. I just go to the hardware store and get a stronger spring. works every time.
2014 Commuter BV350(32,000)/2015 Scoot Life BV350(8,000)/2010 El Diablito SH150i(25,000)
Tue Jan 10, 2017 3:30 pm quote
The first time I did my commuter scooter, I only wiped some grease on the pivot sleeve. One year later, I had to redo it. Then I forced as much grease in the crankcase hole as possible. Been two years and it doesn't stick. That's how I did it to Scoot Life. I prefer to learn from other peoples mistakes. This time people can learn from my mistake.
Tue Jan 10, 2017 3:34 pm quote
Been there done that.
BV350 Another center stand failure
2015 BV350 2007 GTS(sold) 2003 BV200
Wed Jan 11, 2017 2:40 am quote
Being we are on the subject, have any of you guys gone up or down a curb? Have you experienced bottoming out? I thought it was because my center stand was not up all the way. I checked it again it was up same curb at work and it hits.
John
Wed Jan 11, 2017 3:37 am quote
John
Have someone video you while doing this. Could be the force of the front wheel dropping down overcomes the spring. Does your center stand operate smoothly?
Wed Jan 11, 2017 10:44 am quote
breaknwind wrote:
John
Yes I check it the center stand from time to time. It hits going up the curbs too.
John
PX150
Fri Feb 03, 2017 4:17 am quote
Sorted, thorough clean with warm water and a toothbrush shoes the welds are fine, it was just crud and it now springs back to place as it should
Cross Egypt Challenge - A 2400km ride throughout Egypt   Vespa Wasp Neck Scarves   Scooter Parts Company
[ Time: 0.2150s ][ Queries: 23 (0.0445s) ][ Debug on ]
