piaggio mp3 lt 300 yourban
mp3 500 sport
Wed Jan 18, 2017 12:40 pm quote
hi everyone newbie here
ive bought a mp3 lt 300 yourban
ive changed engine oil.and filter also airfilter today ive changed brake fluid as reservoir was empty wonder i had bakes. anyway problem ive got is engine management light is on.ive disconected battery for 5 mins. light only comes on when engine is started as soon as headlights come on.ive read it could be lambda sensor .where about is it has anyone got photo .ps other thing ive noticed is cooling fan is on all time is this normal.....ive taken front end off today fairing. no wiring seems to be tampered with .any help would be appreciated novak
GTS 300ABS, Buddy 125, Typhoon 125
Wed Jan 18, 2017 5:28 pm quote
No, it is not normal for the cooling fan to run constantly. I would not think it would ever come on in January. On my MP3 the fan would occasionally come on during hot summer days in slow, stop and go traffic.
Wed Jan 18, 2017 11:49 pm quote
lambda sensor is on the exhaust just put your hand down by the exhaust cover and feel along the downpipe you cant miss it
mp3 500 sport
Thu Jan 19, 2017 6:31 am quote
fan
anyone know why dan is on all time any ideas would be a help
mp3 500 sport
Thu Jan 19, 2017 6:33 am quote
fan
i ment fan not dan lol
Piaggio MP3 250, BigBeo
Fri Jan 20, 2017 12:02 am quote
When does it switch on? Some time after you start the engine or right after turning key to "On"?
mp3 500 sport
Fri Jan 20, 2017 2:29 am quote
FAN
it comes on just after i start engine as soon as lights come on engine light comes on and fan
Fri Jan 20, 2017 4:39 am quote
What if your mp3 lacks coolant?
mp3 500 sport
Fri Jan 20, 2017 11:44 am quote
mp3
ive checked coolant alls well been for a run today running like a dream no overheating just fan on all time changed spark plug new engine oil filter air filter cheers novak
Gilera Fuoco 500ie
Fri Jan 20, 2017 12:37 pm quote
a relay or fuse or .........
mp3 500 sport
Fri Jan 20, 2017 12:43 pm quote
temp sensor
anybody know where water temp sensor is on gst 300 need help please
Gilera Fuoco 500ie
Fri Jan 20, 2017 12:51 pm quote
on the headvalve unit
mp3 500 sport
Fri Jan 20, 2017 12:58 pm quote
sensor
didnt see it when i changed spark plug.
so take it it must be on other side
Fri Jan 20, 2017 1:34 pm quote
The wire that feeds the ECU with temperature information from the temp sensor may have come adrift/chafed and shorted to chassis.
The wire that comes from the ECU to the fan relay may have chafed and shorted to chassis (unlikely to come adrift).
The fan relay may have arced and welded itself closed.
Easiest to check is the fan relay - just swap it with another.
mp3 500 sport
Fri Jan 20, 2017 1:53 pm quote
thanks
ill#
mp3 500 sport
thanks
ill have a look many thanks
mp3 500 sport
Sat Jan 21, 2017 7:28 am quote
relay
thanks for everyones help.proberbly fed up of me asking for help
but where abouts is fan relay on mp3 300lt ive tried looking on net
mp3 500 sport
Mon Jan 23, 2017 8:46 am quote
thanks
thanks for help ive sorted it out there was a damged wire on temp sensor
fixed it.sorted engine light and fan problem
MP3 LT 300
Sun Dec 16, 2018 12:24 pm quote
Hi where is the code reader socket on MP3
Canít fined code reader socket help need to fined out code for my Engine management light Or how to clear it ?
2009 MP3 400ie
Tue Dec 18, 2018 2:28 pm quote
Re: Hi where is the code reader socket on MP3
Will taking out the battery for 10mins resets the computer?
Piaggio mp3 125
Thu Dec 20, 2018 8:27 am quote
Isnít the code reader socket by the battery where the positive terminal comes out. Should be yellow and black.
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.2734s ][ Queries: 23 (0.0751s) ][ Debug on ]
