Hi I have a et4 125 pre leader and after changing my stator for a brand new one I have no spark? I've tried changing plug and the coil but still no spark?? Plz help 👍🏼
Probably is your immobilizer and cdi. Pre leader ET4s were notorious for their shitty ignition system. You can disable the system and use a cdi from a same era Liberty 125 without an immobilizer. It needs a little modification with some cables but it basically is plug 'n play...
Cheers for the reply, yeah I've got rid of immobiliser a while ago and put in an Athena bypass cdi. Bike ran ok before I changed the stator. The stator is brand new and only changed due to the previous one not putting out enough volts leaving me too little to start the scooter again
All Content Copyright 2005-2024 by Modern Vespa. All Rights Reserved.
[ Time: 0.0409s ][ Queries: 6 (0.0151s) ][ Debug on ][ 313 ][ Thing One ]
