Copy Cat Mirrors
GTS 250ie Red and White
Wed Aug 22, 2007 7:43 pm quote
I saw these mirrors at Amerivespa and decided I had to have them on our scoot. It was a very easy upgrade to do and took about a half hour. Step 1. Slide the rubber gromet up the post of the OEM mirror. 2. Remove the small allen screw and plastic cover at the base of each mirror. 3. Take a 17mm open end wrench and loosen the lock nut then unscrew the mirror post from it's mounting hole. 4. Drill out the mounting hole to the size needed for the new mirrors. The tap and die set usually has a conversion chart on what size hole to drill. 5. Thread the hole using some cutting oil. 6. Put the rubber gromet on the post of the new mirror. Replace the cover and allen screw and screw in the new mirror. 7. Slide the rubber gromet down and that's it. Adjust and ride with a smile.
Wed Aug 22, 2007 7:59 pm quote
WOW!
Those are teh secks!
Thu Aug 23, 2007 6:15 am quote
Re: Copy Cat Mirrors
Yes very nice looking.
M@
Thu Aug 23, 2007 8:49 am quote
much better
Thu Aug 23, 2007 8:50 am quote
Nice!
Mel
White S150 '09
Thu Aug 23, 2007 4:19 pm quote
where can i get some for my lx?
Thu Aug 23, 2007 5:02 pm quote
I picked them out from a catalogue in a cycle store. I particularly wanted the same kind as Jettin had because of how they finished down by the handle bars. I wanted to re use the rubber gromet and make it look stock so these worked well.
01 ET2 - 01 ET4 -- 05 GT200L / 05 PX150 / 1986? Honda CH150 Deluxe.
Thu Aug 23, 2007 5:11 pm quote
Who makes them? Cost? Inquiring minds want to know
Fri Aug 24, 2007 6:17 am quote
They were about $70.00 each and I believe we picked them out of a Kuryakin catalog. Don't know if they have a specific name as I was looking for that specific mirror and it was on the page with many others.
Cross Egypt Challenge - A 2400km ride throughout Egypt   Vespa Wasp Pin Badges   AF1 Racing Vespa Austin
[ Time: 0.1575s ][ Queries: 25 (0.0461s) ][ Debug on ]
