2005 PX150 carb air mix screw
Vespa PX 150
Tue Aug 22, 2017 11:25 am quote
I just rebuilt my carb and it is running better, but it keeps bogging down at certain points. What size is the head on the bolt for the air mixture on the carburetor? I have looked online and everyone seems to have a bladed screw whereas mine is a hex. It's really tough to get into the spot and a socket won't fit. Any ideas?
2016 Vespa GTS 300 super.1979 Vespa px125/177Polini,2005 Vespa p150x Seri America
Tue Aug 22, 2017 12:05 pm quote
It's a 6 mm hex.After you pull the plastic cap off the hex.I modified a 6mm box end wrench in a 90% angle to access it.A little tight with the starter motor in the way but can be done.Have a little patience with that.
2005 PX150 In a Love-Hate Relationship with a 2-Stroke Vespa Since 2007
Tue Aug 22, 2017 4:23 pm quote
There are 2 sizes, 6mm and 7mm. The 6mm ones have slightly rounded edges around the top of the hex head. The 7mm ones are sharp edged. Hard to describe. The long shaft that's hidden under the black cone-shaped grommet is also different shaped but you can't really see that without pulling the carb out.
6mm one
https://www.dellorto.co.uk/shop/dellorto-motorcycle-carburettors-parts/carburettor-parts/si-parts/si-mixture-screw-2/
7mm one
https://www.dellorto.co.uk/shop/dellorto-motorcycle-carburettors-parts/carburettor-parts/si-parts/si-mixture-screw-3/
Tue Aug 22, 2017 4:44 pm quote
Here's what I made to adjust it, which sounds similar to what FunSensei came up with.
A box wrench bent 90 deg with a torch, the other end cut off and ground to a taper, then hammered into a piece of copper tubing to make a nice long handle.
Jet Eye Master
Tue Aug 22, 2017 7:42 pm quote
Ingenious but does that spanner fit in the glove-box?
Another way is to cut about 5mm off the end of the mixture screw, then saw a thin screwdriver slot into the top of whats left.
Tue Aug 22, 2017 8:32 pm quote
Why cut the end off?
I tried the slot idea and the starter motor is in the way.
2005 Vespa PX 150
Tue Aug 22, 2017 8:46 pm quote
Here's mine, inspired by pdxjim's.
Works like a champ!
I did break the wrench on the first bending attempt.
Heated it with a torch for the second one.
Then some glue, some hammering on the copper tube, and a valve stem cap for the final touch.
Jet Eye Master
Tue Aug 22, 2017 9:00 pm quote
Ah, that's because if you cut the slot before shortening it, the starter motor is in the way
Vespa PX 150
Wed Aug 23, 2017 2:18 am quote
Thank you! I think my wrench sets only go to 7mm so I'll have to go shopping and get a couple and see what kind of fun I can have with bending the wrench and see how it goes! Thanks again!
Wed Aug 23, 2017 7:23 am quote
Don't try bending the wrench without torching it or as Aiosi says, it'll break.
1963 Allstate, 2005 Vespa PX150, 2001 Harley 95 ci Dyna
Thu Aug 24, 2017 8:28 am quote
I have had the same issues when trying to adjust my idle mixture screw on my 2005 PX150. I removed the small plastic cap that covered the screw using 12 inch forceps. Then, I turned the screw 1/4 turn counterclockwise using the same forceps. Later, I purchased a 6 mm flexible ratchet that had the 5 degree increments for use in tight places. I then put a small mark on the ratchet part using a gray Sharpie pen. I set the ratchet initially and after an adjustment, I look at the mark and know exactly how far I moved the screw.
My new 2005 PX150 is now running great with no off idle bog. It pulls strong from zero to top speed and is a real pleasure to ride. For reference, here are the adjustments made to my 2005 PX150:
Main jet stack: 102/BE3/160
Slow idle jet: 55/160
Drilled air cleaner
Slow idle screw: 1/4 turn CCW beyond the stock setting of 1 3/4 turns.
SIP Road 2 muffler
NGK BR7HS spark plug
2005 PX150
Idle mixture screw 6 mm on back of air box protruding through rubber grommet. .
Flexible 6 mm ratchet with gray mark for orientation.
T5s
Thu Aug 24, 2017 10:10 am quote
Bell ends
Don't fuck about ..... shove a socket on one of these ..... Some people just wanna make life hard
If the sockets too deep put a nut inside first
Thu Aug 24, 2017 11:29 am quote
Re: Bell ends
You obviously do not have a PX with electric start and want to adjust your idle mixture screw.
74 Rally 200. 79 P-whatever
Thu Aug 24, 2017 11:34 am quote
starter motor makes things more difficult than they need to be haha.i always used a swivel socket with smaller ratchet set, works fine.
T5s
Thu Aug 24, 2017 12:15 pm quote
pfffftin
electric start .... do i look lazy
Thu Aug 24, 2017 12:53 pm quote
Re: pfffftin
PX 125/Polini 177
Wed Jun 12, 2019 9:12 pm quote
Mixture screw etc
All good suggestions here, I have a 7mm ratchet spanner on order.
I have not found an answer to another example of cunning Italian engineering. On top of the air box is a rubber grommet, remove it and there is a screw. Itís simply described as a screw in the Haynes manual. But it has a pointed bottom end, it appears to hold the filter in place, but does it actually have a function. I canít find it mentioned in the sip guides, or anywhere else. Huh?j
Wed Jun 12, 2019 9:32 pm quote
This has been discussed in other threads. Itís the ďwinterizingĒ plug. Some call it the ďsummer plugĒ, donít ask me why. Itís meant to be a way to squirt oil into the carb without having to remove the airbox cover or air filter.
PX 125/Polini 177
Wed Jun 12, 2019 10:48 pm quote
Winter plug
Thanks for the answer. It may have been discussed before, but as someone new to the forum, and not knowing what the thing was called it would have been difficult to find former threads...
1978 MotoVespa 160GT, 2009 LML Star 150 2T (Stella), 1961 Lambretta S2, 1962 Lambretta S3, 1964 Lambretta J100
Thu Jun 13, 2019 2:21 am quote
I've also wondered about that special screw. Maybe I'm missing something, but why would you want to squirt oil into the carb?
PX 125/Polini 177
Thu Jun 13, 2019 3:04 am quote
Reply to norm
Iím guessing, if youíre laying the scoot up for winter, to inject some oil into the cylinder..
Thu Jun 13, 2019 3:09 am quote
Could be, but I would have thought a squirt down the spark plug hole would be more direct though.
Thu Jun 13, 2019 3:10 am quote
For winter conservation.
Your meant to add oil in the engine and do a few turns on the kick-start so there is oil inside.
I usually did this by removing the spark plug, but some Italian engineer figured it out without removing anything, other then the winter plug.
Thu Jun 13, 2019 10:24 am quote
The plug and the screw. Iím not sure thereís really much of a user advantage, but I could see there being one during manufacture and distribution, especially if the product is expected to potentially sit in extended storage before sale. This way, torqued factory assemblies only need to be minimally disturbed.
05' PX150
Tue Jun 18, 2019 8:29 am quote
I used my Dremel with a grinding blade to cut and shorten the hex head on the stock mixture screw and again to cut a slot in the head of the shortened screw. Now I easily access the mixture screw with a long skinny flat head screw driver no problem.
PX 125/Polini 177
Wed Jun 19, 2019 8:56 am quote
Mixture screw spanner
This works a treat
Rallies Europe 2016   vespa scooterwest scooter west Motorsport Scooters   Scooter Parts Company
[ Time: 0.3588s ][ Queries: 27 (0.0850s) ][ Debug on ]
