Px125 1993
Fuel leaking from the exhaust pipe.
Opened the Carb and partly disassembled but everything looked in order. All tubes, connections seem to be right on... strange. Maybe I should totally remove it and more closely inspect.
Thought the engine was flooded.. took out plug and it was in order and sparking... suggestions?
Its definitely fuel (not condensation).... several weeks prior it kicked right up (pretty smoky but i figured it was the gas/oil mix).. now it wont start at all and the more i kick it the more gas comes out the exhaust.
Initially I thought it was because I left the fuel valve "on" but after having it shut for several days- the same effect when kicking.... gas out the exhaust (and spraying not just dripping)
