So I have a PK frame that doesn't have a fork, headset, or hub.
-I have both an extra P fork (16mm) and P headset in my shop.
-I have an extra Grimeca 16mm disc brake assembly.
-A friend has a PK50 fork.
-I know a guy with a welder.
I stuck the P fork in the PK frame "just to see" how close of a fit it would be. It didn't look like it was going to fit whatsoever because the aluminum casting at the upper shock mount is completely the wrong shape and size.
Is it possible to use the upper portion of the PK50 fork in the frame, and the P fork for the lower portion?...then bolt the P headset to the top of the PK50 fork? Of course that would mean cutting both forks and welding the two together. I guess the main issue would be if the upper and lower shock mounts would be inline with each other.
Why not just use a PKXL fork? Well, #1 I don't have one, and #2 my 16mm Grimeca won't fit on the 20mm PKXL fork. #3 the PX halogen headlight puts out better light than the PK headlight.
AND I DON'T CARE IF THE P HEADSET LOOKS STRANGE ON A PK. I think Oopsthudclunk's PK looks sweet with that PX headset.
