So what the heck happened? Life of course. I figured I would post an update of all the work that has been done. But first, thanks for your responses. RowdyC, you were correct that some of the coils were toast and the problem was rectified with a new stator.
Although I haven’t posted in 2 years, I have been lurking the whole time to solve problems. Huge shout out V oodoo, Socalguy, Ginch, Robhodge (I know I missed a few names) for your contributions over the years, they were very helpful in explaining some of the finer points of Vepsa’s. Also the Australian Guy whose scoot was caked inside and out with red dirt, great pics and your documentation was useful (I think I also stumbled upon your wordpress site as well).
Below are the mechanical updates. Bike is running/driving and legal. I can take her on 30 minute rides no problem (sort of, no rear brake).
New Tires and Tubes – I had to get the local shop to stretch the new tires on the split rims. Even after putting the tires in the oven, I could not get them to stretch around the rim, not squish the tube, and then put the two halves of the rim together.
Cleaned Fuel tank and replaced fuel tap – The fuel tank was not just rusty but also hard a hardened goo in it. It took multiple rounds of going back and forth between terpentine (to remove goo) and Evaporust to remove rust. At times little small metal balls (BB’s) were used to bang off the stubborn rust. The picture is after the first round of cleaning and not the final product. Fuel tap was not the best and I ended up plugging it to act as my stopper at the bottom of the tank during the cleaning process. This work was done 2 years ago and kept the tank relatively clean even though I did not use POR15. **Insert pic of old tank after first cleaning & tap**
New Elec Accessories – New headlight, new taillight, new brake switch – Old sealed headlight was not great, so replaced with more modern housing that also had a pilot light. Original VBA taillight was period correct hacked together, but for $20 I though a new one on for now. **insert pic of original VBA taillight**
Stator and new wiring – I replaced all the wiring in the bike, unfortunately I decided to make my own wiring harness. Do not ever make your own harness unless you have too! I did it because there seems to be a few wiring harnesses floating around out there and I did not want the wrong one. Also I wanted the experience of fully understanding the wiring one wire at a time. Final product came out well though. From a cost standpoint, after buying 10 colors of automotive wiring, it was about the same as just buying a replacement harness. New wiring did help get power to the front, but it was still weak so I replaced the 6 wire stator with a 5 wire stator. It took a little hackery to get it to work, however the lights and horn work great. **Insert pic of making wiring harness, show old stator vs new **
New outer and inners & new pinch bolts – It is a pain, but we all need a good cry sometimes. Replaced all cables except choke, but that is the easiest one.
New levers – Not a big deal but wanted to mention this as my old ones were super ovaled out and I could not find the sweet spot for the clutch adjustment (ie hole over time drifted and reduced leverage).
New Exhaust (VBB stock equivalent) – This was a must as the old exhaust was filled with crap. Probably a 1lb different between old exhaust and new exhaust. This really helped the engine breath.
New front Shock/Spring – The front would instantly dive upon braking on the old setup (old damper was completely shot). I bought a new normal spring and a BGM damper. Now the front still dives on braking, but doesn’t bottom out like it did. I have played with the damper setting, too hard made the bike extremely rough over bumps. **Insert picture of new setup**
New carb and carb box – I also decided to switch from a 20/17A (air flapper choke) to a 20/17C (fuel enrichment circuit for choke). Don’t worry this came with the bike along with the correct carb box to match. Carb was rebuilt and almost correct stock VBB jetting (air correction is 160, could not find 140). Funny story, if you play with carb adjustment screws and nothing happens, you probably forgot to put in the paper gasket in your haste.
I hope to have the next installment here in a couple weeks where I will talk about my learning experience with rear oil leaks, centerstands, gas tank vent tube, and maybe get the speedo working. I am hoping to split cases in next few weeks to replace gasket, seals, and bearings.
Old gas tank fuel tap
Old Gas Tank after one round of cleaning.
VBA Taillight guts had been ripped out in the past and replaced with a dual filament bulb.
Creating the wiring harness.
New 5 wire stator (Left) vs old 6 wire stator (Right).
My hack way I had to create leverage to oppose the spring force to get the damper in place (Damper will not fully close when compressed and the spring was brand new). I was doing this by myself, if I had 2 people I wouldn't have had to be so creative.
New spring and BGM damper installed.
