evap is there any point removing??
carnaby 125
Fri Aug 17, 2018 12:57 pm quote
I hear people on here removing it but on my piaggio 125 is a different evap system to vespa
I would after blank plate it that's only option
also is there any point removing it
I don't have any issues running or starting
2007 LX 150 (memories)
Fri Aug 17, 2018 1:15 pm quote
Are you sure you have an evap system? I thought those were only US Vespas to comply with EPA regs.
https://www.gov.uk/emissions-testing
carnaby 125
Fri Aug 17, 2018 1:19 pm quote
Well in UK known as sas valve
Fri Aug 17, 2018 1:21 pm quote
Apparently, you are exempt from testing because you have two wheels. See above link I added.
If it runs OK, why not just leave it?
BV250
Fri Aug 17, 2018 1:52 pm quote
The correct answer is to maintain and replace vacuum lines as needed so that the evap system doesn't cause running problems.
For those willing to risk tipovers and fuel spills, the removal is great in order to eliminate the evap system as a source of vacuum leak and prevent fuel delivery issues due to overfilling or fuel getting into those tubes, causing improper flow of air in the tank. If any of these things are a problem and one wants to take their chances, that's when to do the evap mod.
I did mine. That should be telling One bonus was a rubber strap that I could repurpose as a battery hold down which I was missing.
carnaby 125
Fri Aug 17, 2018 2:01 pm quote
I leave it as it is as so for I not got any issues at the minute
2014 Commuter BV350(34,000)/2015 Scoot Life BV350(9,000)/2010 El Diablito SH150i(28,000)
Fri Aug 17, 2018 2:11 pm quote
SAS is the secondary air supply. The Evap catches hydrocarbons that escape the fuel tank and returns it to the intake system. The SAS injects air into the exhaust system for a more complete burn of exhaust gases.
Fri Aug 17, 2018 2:17 pm quote
The only time it's needs to be removed is when you use an aftermarket exhaust to stop deceleration popping.
Fri Aug 17, 2018 3:36 pm quote
A completely different system to the carbon canister Evap Crap the US has to endure. I'll add - it's not that crap on other vehicles, but it is on Vespas and some other motorcycles because of the fuel tank and fuel system topography.
GTS 300ABS, Buddy 125, Typhoon 125
Fri Aug 17, 2018 6:29 pm quote
^ ^ ^ Bingo! ^ ^ ^
2016 BV350 White
Thu Sep 13, 2018 10:56 am quote
The evap crap takes up alot of space in my pet carrier. This would be a good reason to remove it, so I can use that space.
Thu Sep 13, 2018 11:49 am quote
And that would have been the only reason I would have ever considered removing the evap system from my BV 350. It worked fine all the time I owned the bike. Given the position of the fuel tank in a BV 350, I'd guess it would be even more trouble free than the evap system on an MV.
2016 BV350 White
Fri Jan 11, 2019 12:36 am quote
FWIW, I completely fill up my BV350's gas tank every time I get gas and have never had an issue with fuel filling up the evap canister which is why I still haven't removed it, yet. If I did it would have been long gone. I think that this is more of an issue for the smaller vespas that don't have their gas tank so lower in their bikes.
Sat Jan 12, 2019 8:10 am quote
Unfortunately it isnít.
I endured popping on deceleration, throttle hesitation, erratic idle and stalling after startup on my Ď13 off and in for five years. I had it reprogrammed at the dealer when new software was available, Iíve changed the plug, cap, plug wire, etc. nothing mattered. Then about 3 weeks ago I finally removed the evap system. Itís a different scooter now. All - and I mean every single one of those issues are now gone.
The evap system on the BV350 is an afterthought, and thatís about how well it functions. Beyond that I am not a fan of evap systems that donít have a purge valve controlled by the computer. With a purge valve the computer decides when to cycle it based on current operating parameters, and is mapped for the introduction of extra fuel vapors during those conditions. The Piaggio system has no such control and relies on afterburn feedback to tell it whatís happening. The result is a system that is constantly adjusting fuel trim to chase a moving target. Thatís way less than ideal.
Sat Jan 12, 2019 9:53 am quote
If your evap system is malfunctioning, then certainly fix it or remove it as you choose. My comment was that the evap system on my '13 BV350 worked fine, as have the evap systems on the other 6 Vespa and Piaggio scooters I have owned. Yes, I understand there are evap systems that have failed. This Forum is also full of stories where an individual has a rough running scooter, others tell him to pull the evap system, he does, and it makes no difference. Best to fix the problem you actually have IMO.
2008 MP3 500, 2013 BV350
Sat Jan 12, 2019 3:52 pm quote
Do you fill your tank to the brim?
Do you have hot weather that will cause excessive expansion of the fuel in the tank?
Those are two contributing factors.
Fill to the top all the time in hot weather and I would be amazed if the problem didn't happen.
Sat Jan 12, 2019 4:22 pm quote
I removed the EVAP immediately after purchasing my BV's for space. I don't live in CA., so I didn't break any laws. But I did have stalling and popping on deceleration after EVAP removal on the 2014 that was solved by a remap.
2018 Yamaha Xmax (Max), 2006 Vespa GT (Rocket): 2005 Vespa GT (Razzo): 2007 Vespa GT (Vanessa): 1965 Lambretta Li 125
Sun Jan 13, 2019 3:02 am quote
My 2006 GT, Rocket, had one big issue within the first year.
In high speed runs, it would suddenly lose some power and slow from running in the 70ís to the mid 60ís. The engine temperature would go up as well and it would run poorly until I came to a stop, then headed out again. It would run normally until pushing the speed up again.
But some times it wouldnít do that. I ran the Cannonball in 2014, almost wide open for nine days without ever doing this.
Then, a few years ago it started giving me big problems.
Out on rides it would stumble badly, cut out and three times, stop running entirely. Two of those had me pushing it home, once one mile, the other almost three miles.
So I looked up a way to bypass the evap system, performed the simple procedure, and never had either problem again.
I did the same to Vanessa and Razzo too.
In an effort to get as much distance as possible out of each tankful of gasoline, I do fill the tank to full. Every now and then, fuel will drip put of the new bypass hose onto the ground when over filling. That fuel would have gone into the canister, wreaking havoc to the engine performance.
Bill
2012 GTS 300
Mon Jan 14, 2019 9:13 am quote
Funny enough when I took my bike into the shop for a tune up (new plug, air filter, new belt, oil change) when I got her back she was also missing the evap can. Hey no complaints here
Looks like they did not plug the one nipple however and so I guess I do have a vacuum leak (or really, excess air in the intake stream I believe? will need to take another look) but it runs fantastic so I haven't been bothered to change it.
I *do* however get the deceleration popping - don't necessarily mind it. Unless it's harmful? I'm trying to understand what is going on in the engine to make it pop like that. Improperly timed combustion? Why only on decel?
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.2960s ][ Queries: 23 (0.0349s) ][ Debug on ]
