P150x Wet spark plug - occasionally stops sparking in city
P150X
Tue Aug 21, 2018 3:14 am quote
Hello, my p150x is all stock with the si20/20 carb. Currently spark is always wet. From low rev to mid, slight purring/misfire but overall not an issue. The big issue is that the Vespa can stop on the road, and when I pull the plug, itís totally wet and sooted, and wonít spark, I would clean on the street and it would spark again. The spark plug is brand new, it did this 3 days ago, so I bought another brand new one hoping it would help but same problem. Spark plug is NGK B7HRS.
I was thinking that the spark plug is too cold and would get a B6? And see how that goes? What about getting the carb to spray less fuel on the plug? How to do this? Thanks
P150X
Tue Aug 21, 2018 4:19 am quote
Ok so I couldnít wait, first pic shows the NGK BR7HS plug, Black sooted and wet at the gas station, I bought a NGK B6HS (hotter and without the resistor) and after doing a ride home I pulled the plug out and shows in pic 2, looks perfect to me! Weíll see. Dry and brownish. So plugs do make a big difference it looks like. Drove great as well. Ok canít upload 2 pics at the same time, first shown is the previous one
P150X
Tue Aug 21, 2018 4:20 am quote
Here is the B6HS plug
Tue Aug 21, 2018 10:28 am quote
Did the plug dry out because there is now no oil in the gearbox?
P150X
Tue Aug 21, 2018 10:35 am quote
No no, that problem has been solved! I split the engine casing and changed the gear oil O-Ring.
When I did that job I also did the crucifix and installed a new spark plug that the store suggested which was not really good.
Tue Aug 21, 2018 11:02 am quote
Check the oil again. Make sure it is still there. Vespas have a habit of making it dissapear.
P150X
Tue Aug 21, 2018 11:07 am quote
ok, good tip, will check that out.
Kymco AK550
Tue Aug 21, 2018 11:46 pm quote
From the pictures it is still wrong even with the hotter plug. Running rich could be carburettor flooding or air filter clogged up. If it is worse when idling then flooding is the most likely cause. Also check the cold start system, I don't know whether that is mechanical or automatic on this model.
P150X
Wed Aug 22, 2018 4:28 am quote
Thanks, the picture wasnít that great to see the electrode it was dry and nice and grey/brown. The wetness you see was from the thread from before. Scooter runs really well now, not sure for how long. The choke is manual and works well on cold start
P150X
Wed Feb 12, 2020 12:26 pm quote
I was googling for this problem, and I came across my own post about the same problem!
This has not been solved. Spark plug up to the thread wet. Wondering what this can be. I mention the thread is also wet because this can lead to other things, like piston rings? Once I clean the spark plug, all is well for a couple of days, then maybe a week later, problem again.
Wed Feb 12, 2020 12:37 pm quote
Do you have a standard 20/20 carburetor with the correct jetting, or has it ever been messed with? Do you know what size jets are installed?
The same question goes for your exhaust. I read the motor is still a stock 150.
P150X
Wed Feb 12, 2020 12:41 pm quote
all is standard/stock
The same question goes for your motor and exhaust- still stock 150 or has it been modified?
Wed Feb 12, 2020 12:44 pm quote
I revised my post too late, you had already replied. Do you know what the jetting is set at in the carburetor? Are you comfortable opening up your carb and telling us what numbers are stamped into the jets?
Cross Egypt Challenge - A 2400km ride throughout Egypt   vespa scooterwest scooter west Motorsport Scooters   Scooter Parts Company
[ Time: 0.1609s ][ Queries: 27 (0.0420s) ][ Debug on ]
