Switched the atomizer to a BE4 (lots of mixed info ou there on whether that is richer or leaner than a BE3) and seems to be much better.
P200 with 24/24 carb. Pollini 208 kit with Sito Road exhaust.
Currently running 135/BE4/60 main stack.
55/160 pilot/idle.
Idle screw is set at 1 5/8 turns out.
Air mix screw is at 3.5 turns out.
Here is the motor idling - how does it sound to you guys?
