Help wanted on lowering rear shocker vespa lx
Vespa lx,1967 vespa v90
Mon Oct 01, 2018 3:27 am quote
Is there any way of lowering the rear shocker on a Vespa Lx,I have already lowered the seat and stretched the wifes legs on a homemade rack but to no avail,I have noticed the shocker bracket can be moved down the engine case,I'm not sure if this is for adjusting the ride height or just used on a different model,I have tried it but the shock seems to be on a too shallow angle.
thanks in advance..
09 190s taormina
Mon Oct 01, 2018 4:51 pm quote
PJS wrote:
I have noticed the shocker bracket can be moved down the engine case,I'm not sure if this is for adjusting the ride height or just used on a different model.
Not for lowering. Only option would be to cut coils.
S 190. Custom VNB 150
Mon Oct 01, 2018 8:04 pm quote
Cutting the coils will ruin the shock. They are temperd and it will loose all of it spring. I tried this and I was a waste.
Look into platform boots for a smaller rider. How much clearance does she need? You also don't need to be flat footed at a stop with the scoot straight up in the air.
2018 GTV300 SG, 2012 LXV 125ie 2V, 2015 Primavera 3V 150ie and V90
Mon Oct 01, 2018 9:10 pm quote
I am very short (52) and 28 inseam, just use boots with 1 plataform or just put left feet down and tilt it a bit. Dortunatelly the LX is very light.
lx 50
Mon Oct 01, 2018 10:10 pm quote
Would a higher spec adjustable shock work. Meaning you can build some sag into it when she gets on.....like you do on a mountain bike?
Mon Oct 01, 2018 10:41 pm quote
Thanks for the replies,unfortunately the wife is just under 5ft,I've seen the lower shock you can buy for the front and I'll take what I can off the seat,the rear shock looks the same type as on other vespas,I wonder if there's a slightly shorter one on a different model..
Mon Oct 01, 2018 10:49 pm quote
I had to get a lower seat for the Vespa 90 so she felt more confident..
LX190, Primavera
Tue Oct 02, 2018 12:27 am quote
Moving to the other mounting location is probably a little extreme, but you can reverse the mounting bracket which will lower it slightly.
Did you put the lower S seat on?
09 190s taormina
Tue Oct 02, 2018 3:10 pm quote
Shock is travel limiter. Shorter shock if you can find one carb will hit the pet carrier.
Wed Oct 03, 2018 12:53 am quote
yes I changed the seat,i'll see if i can get it shaved,i'll try the bracket as well..
thanks
Wed Oct 03, 2018 12:54 am quote
Cheers..
Land of 10,000 Scoots Rally   vespa scooterwest scooter west Motorsport Scooters   Scooter Parts Company
[ Time: 0.1750s ][ Queries: 27 (0.0365s) ][ Debug on ]
