09 MP3 500ie computer
09 red MPe 500ie
Thu Oct 25, 2018 6:31 am quote
Where can I order a tilt lock computer. 903.05.0101.07A
Thu Oct 25, 2018 10:11 am quote
Re: 09 MP3 500ie computer
any piaggio dealer can order that. check with AF1 racing they are a sponsor on the forum here.
2016 MP3/500 Sport ABS, 2009 MP3/250, 2012 GTS Super 300ie
Thu Oct 25, 2018 10:51 am quote
I saw one on ebay this morning...
I have had good luck buying them vs paying New.
Keith,
Marietta, GA
Thu Oct 25, 2018 11:02 am quote
Newer Rev for the Part Number 640439.
This would work on all the MP3 Model 250, 400, and 500.
https://www.ebay.com/itm/2016-14-16-PIAGGIO-MP3-500-ABS-SPORT-ECU-CDI-MAIN-COMPUTER-BLACK-BOX-OEM-TESTED/362433713234?hash=item5462bb9452&autorefresh=true
09 red MPe 500ie
Fri Oct 26, 2018 8:38 am quote
I ordered it but the company thinks it will not work on my 09
09 red MPe 500ie
Fri Nov 02, 2018 4:00 pm quote
update the computer wasn't needed as the tilt lock system was broke. Ordered one from an 09 400 and with minor adjustment (put 500 lug on 400)all s well
09 red MPe 500ie
Sat Nov 03, 2018 6:04 pm quote
as a side note, computer wasn't bad it was a broke tilt lock motor
Gilera Fuoco 500ie
Sun Nov 04, 2018 2:19 am quote
The tiltlock motor rearly goes bad most likely the pot meter did get a few degrees off can be resetted manualy by taking of the wiper engine beneeth and set the pot meter to 12 degrees so it won't beep anymore stick the engine back 3 bolts and no problem
Mp3
Sun Nov 04, 2018 11:28 am quote
It was the tilt lock. The older versions had a weak connection behind the black plastic door. This is what connects the tilt motor to the tilt hydraulic. Ours (OP) was broke. Luckily for us or new motor had the upgraded connection. To synchronize without a computer we just adjusted the small screw on the back of motor while monitoring wire 5B going to tilt computer. Needs to be 4 volt and 1 volt locking and unlocking.
Gilera Fuoco 500ie
Mon Nov 05, 2018 10:35 am quote
never had one that broke and i've done enough mp3's Fuoco that did have tiltlock problems of some kind
Mp3
Mon Nov 05, 2018 3:51 pm quote
Here is a document about the upgrade. Our original had a very weak connection. Do you know if most of the mp3's you've seen have the newer connection? The other improvement is that the assembly is now adjustable.
Fuoco 500ie - 2007, Benelli Adiva 150 - 2003
Tue Nov 06, 2018 12:33 pm quote
What beep signals did you get?
Mp3
Tue Nov 06, 2018 1:06 pm quote
I remember we were getting the solid red tilt lock warning and I think we were getting a beep every second or two. Maybe jsheedy (OP) can remember more specifics.
I had previously checked almost every sensor at the tilt computer connector.
In our case you could see the broken connection behind the little plastic /rubber cover.
Hope the helps. Feel free to ask other questions if you think we can help
2019 Spring Gathering - May 16 - 19, Location TBD (Likely Maggie Valley, NC)   vespa scooterwest scooter west Motorsport Scooters   Cool Ass scooter seat cover
[ Time: 0.3167s ][ Queries: 25 (0.0927s) ][ Debug on ]
