Vespa GTS ABS ring rubbing against shock absorber support
GTS 300
Sun Jan 06, 2019 2:03 pm quote
Hi folks. Has anyone came across this issue before where the ABS ring in the brake disk is rubbing against the fork bracket.
Sun Jan 06, 2019 3:02 pm quote
Looks like spacers must have been in the wrong order.
GTS 300
Sun Jan 06, 2019 10:52 pm quote
My thoughts exactly , but only spacer is ring and washer which were in it already .. will take another look tonight on the chance I missed something.
GTS 300
Mon Jan 07, 2019 12:37 am quote
Okay, when back over the full set up and all parts, washers , pins etc are all set correctly on the hub and wheel axle .. I am waiting for the parts company to double check the new fork details they send me , as starting to suspect the wheel axle is a different length or something .
GTS 300
Mon Jan 07, 2019 12:45 am quote
Another point , could my torque wrench be faulty and I am over tightening? What happens when you over tighten, could I have damaged bearings ?
LXV 150 3v ie. Midnight Blue (Sold)
Mon Jan 07, 2019 12:51 am quote
More likely squashed something. Like a washer.
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   vespa scooterwest scooter west Motorsport Scooters   AF1 Racing Vespa Austin
[ Time: 0.1536s ][ Queries: 26 (0.0365s) ][ Debug on ]
