Vespa 150 (vbb1t) oil seal on the rear wheel breaks week
Vespa 150 VBB1T
Sat Nov 24, 2018 2:19 am quote
Hello, everyone!
I have a 1961 Vespa 150 and my oil seal in the rear wheel breaks everytime I get a new one. The wheel wobbles a lot and my l breaks are almost non-existent. It's been 6 months and I'm not getting any permanent solutions. Please help me with your valuable opinions.
Thu Nov 29, 2018 1:42 pm quote
The rear hub is probably worn out on the splines.
68sprint,65super,64Allstate,55 Allstate
Thu Nov 29, 2018 4:20 pm quote
Vespa 150
Iím going to say what Ginch has said, plus Iím going to say the splines on the axle are damaged as well. Scott
2001 LML 150
Thu Nov 29, 2018 4:30 pm quote
I'm going to ask.. how's the surface on the shaft where the seal contacts it? Scratches or pitted with corrosion will cause leaking past the seal.
Thu Nov 29, 2018 5:55 pm quote
Surface is on the hub Phil.
Usually the damage is done to the hub and the driveshaft is ok. But if it's been ridden for some time like this you never know.
2001 LML 150
Thu Nov 29, 2018 6:21 pm quote
There ya go.. you learn something everyday!
2001 LML 150
Fri Nov 30, 2018 12:48 pm quote
I had a look at the design... Hmmm..
Am I right in thinking, if the splines are worn and the hub's got movement on the shaft, the seal's just going to flog out in no time?
Fri Nov 30, 2018 2:49 pm quote
Yes indeed!
Cross Egypt Challenge - A 2400km ride throughout Egypt   vespa scooterwest scooter west Motorsport Scooters   AF1 Racing Vespa Austin
[ Time: 0.2917s ][ Queries: 23 (0.0540s) ][ Debug on ]
