soaking clutch
Molested & Abused 2003 Stella 2T
Fri Nov 30, 2018 8:10 am quote
My new SIP clutch arrived yesterday. I know I am supposed to soak it in 30w oil (our "gear oil"). Do I need to use a u-clamp or something to open up the clutch plates to allow the oil to get to the surface of the plates, or can I just drop the clutch as is in a bowl of oil and let it sit overnight?
'81 Special, '78 P150X, '13 LML Star 200
Fri Nov 30, 2018 8:22 am quote
ofc better open your clutch
1980 P200E, 1974 Primavera, 04 Ninja 250
Fri Nov 30, 2018 9:40 am quote
corks out or you'll regret it
might as well use a pick to get the grooves clean at the same time for better oil flow out
1976 Super (x 2), 1974 Primavera (x 2), 2006 Fly 150
Fri Nov 30, 2018 10:20 am quote
Yeah, take it apart. FWIW, last new clutch I bought arrived pre-oiled wrapped in a slimy plastic bag.
Fri Nov 30, 2018 12:38 pm quote
I vote compress it and soak in a bowl. They actually need very little oil in operation so I reckon that's more than enough.
68sprint,65super,64Allstate,55 Allstate
Fri Nov 30, 2018 1:52 pm quote
Clutch soaking
Never thought about compressing the clutch and soaking the whole clutch. I assume that....it would work. Allows a little bit of gap in between the corks for oil to soak in. I have always disassembled the clutch and soaked separately. Next time I will try soaking the whole clutch with the clutch compressed. Scott
Fri Nov 30, 2018 2:31 pm quote
Compressing and soaking wastes more oil
Fri Nov 30, 2018 2:52 pm quote
It does, but if the clutch is clean there is nothing to stop you re-using the oil. And if you really can't be arsed pulling it apart then it's a not entirely unreasonable comprimise.
Fri Nov 30, 2018 2:59 pm quote
Interesting. I hadn't thought of taking it apart. I guess the lazy side of my brain is asking, if it has to be taken apart to be oiled, why do they ship it assembled?
Fri Nov 30, 2018 3:04 pm quote
Somehow there’s always some grit or spiders in the oil and I end up tossing it
Sat Dec 01, 2018 9:33 am quote
Put the corks in a seal-able sandwich bag, pour in some ND oil, seal it, give it a shake and let it set overnight. Or a month
Sat Dec 01, 2018 11:33 am quote
I've done this for spare plates on long rides, and even had to use them. They had been "soaking" for about 9 months. does not take much oil in the bag and no dust or insects...
2005 PX150 In a Love-Hate Relationship with a 2-Stroke Vespa Since 2007
Sat Dec 01, 2018 2:46 pm quote
Wetting them yes but I’m not sure I’d immerse them overnight. There have been posts about the corks expanding too much and causing adjustment and shifting issues. Because they’re vertical, when parked excess oil runs back into the gear case. When running they get oil flung on them and they fling a lot of it back off.
Sat Dec 01, 2018 3:13 pm quote
Clutch soaking
I have had a bunch of wet clutch engines. I have done this both ways. 1. Took the clutch apart and soaked the corks reassembled and road the bike with no issues.
2. Took the clutch out of the package installed it in the engine and have had no issues.
3. I just bought a complete clutch for my p200e...took it out of the package and installed it. I did not soak anything. I ran the engine on the stand for about 10 minuets to sling the oil around, popped it in gear and took off. Clutch works great. Go figure. Scott
Rallies Europe 2016   Vespa Wasp Pin Badges   AF1 Racing Vespa Austin
[ Time: 0.2058s ][ Queries: 23 (0.0466s) ][ Debug on ]
