Walbro pilot jet problem?
ET125 & ET2
Mon Dec 03, 2018 1:41 pm quote
I am trying to get an old ET125 running. Have stripped the carb, cleaned with carb spray and airline and put back together. Carb is Walbro WVF and label on autochoke lead says it's a 6e but nothing on actual carb
Carb back on but not happy. Can only get to run on choke which would suggest clogged pilot jet. Stripped down again and can only see the tiniest pin prick of light through the pilot jet. No number anywhere on jet but Haynes manual suggests it should be 32 in which case jet aperture should be 0.32mm. Can't get a 0.16 guitar string through it.
Wondering whether stick in some kind of solvent bath or take a 0.3mm drill to it?
Would buy a replacement but cannot find Walbro pilot jets anywhere
Any help greatly appreciated
MP3 500, GTS 250 (both 2008 MY), 2010 Can Am Spyder RT-S, 2012 Honda NC700 DCT
Mon Dec 03, 2018 2:23 pm quote
I'd start with solvent certainly.
A drill bit, hand held, will often go over-size and out of round.
Leave the jet in solvent overnight. Push the pin through tomorrow.
2008 MP3 500, 2013 BV350
Mon Dec 03, 2018 2:35 pm quote
Use jet drills, I've had these once since the 80's when I was turning wrenches on bikes.
https://www.micromark.com/The-Rogers-Drill-Bit-Set-61-80-Set-of-20?gclid=Cj0KCQiAxZPgBRCmARIsAOrTHSbw--kzLto48e6sreITz0WRxRQSjZPc9UsBptGDhuRYglqiM993gUwaApR4EALw_wcB
Mon Dec 03, 2018 4:13 pm quote
Boil jets in microwave.
Scarabeo 150, Scarabeo 500ie, Triumph T120, W650, Super Sherpa, Vespa 150 Sprint
Tue Dec 04, 2018 5:26 am quote
Or just buy a new jet.
fried okra
ET125 & ET2
Tue Dec 04, 2018 7:15 am quote
Thanks chaps
Jet currently soaking.
Will get more physical if needed
Would love to buy a new one but cannot find a source for Walbro pilot jets
ET125 & ET2
Wed Dec 05, 2018 6:13 am quote
Prob sorted and got to admit to a schoolboy error. Neglected the fact guitar string gauges are in thous of inch so was trying to get too fat a wire through the jet anyway!!!
Soaked it, sprayed it through with carb cleaner then air (used the shoe cleaner compresser at the golf club ). Did same on main jet and all pathways through carb
Back on, fired up, job's a goodun!
Wed Dec 05, 2018 6:15 am quote
Wed Dec 05, 2018 4:22 pm quote
Awesome!!
Your Rally Here   Vespa Wasp Pin Badges   AF1 Racing Vespa Austin
[ Time: 0.4234s ][ Queries: 25 (0.0979s) ][ Debug on ]
