Help: Sparkplug and Cap for Vespa 90
2018 GTS 300 sei giorni, 2012 LXV 125ie and V90
Tue Dec 04, 2018 11:38 am quote
Hi evryone! I searched and could not find another thread regarding this. I want to make sure I am using the correct sparkplug and need to buy a cap for a vespa 90 from 1966. SIP website shows many options and I am confused. Anyone know which one should I buy?
I am using a BP7HS and it has a brass fork but no cap, only tape.
I guess I need to replace the fork , buy a new cap and HT lead. But not sure which version to buy. Chasis is VA1T23824
Sorry for so many pictures.
This is how it is now, of course tape is not good enough to hold it.
It has a brass fork but no sheath. Should I buy a plastic/rubberised cap?
Manual indicates Bosch W240 T1 or Champion L81.
Confused by so many options.
a herd of easy shifty rats
Tue Dec 04, 2018 12:06 pm quote
You just need the rubber cover, the 2nd one on the list - #16. Your original brass connector fork looks to be in good condition but it needs the spark plug to have that little round threaded aluminum cap on top which it is designed to snap onto securely so you don't need tape to hold it on.
Use an NGK B7HS sparkplug. Notice the separate grooved cap that the brass fork snaps onto which you are missing. Also you probably know, but you are missing the plastic cylinder cover which needs to be in place for engine cooling.
Tue Dec 04, 2018 1:15 pm quote
Thank you! Is this correct?
1980 P200E, 1974 Primavera, 04 Ninja 250
Tue Dec 04, 2018 1:52 pm quote
no, screw the little bit down all the way and wrap the plug prongs around the thin bit at the middle of it.
Tue Dec 04, 2018 2:29 pm quote
Got it, thanks!!!
2005 PX150 In a Love-Hate Relationship with a 2-Stroke Vespa Since 2007
Fri Dec 07, 2018 5:07 pm quote
I donít know those early bikes, but is there no air cooling cowl?
Fri Dec 07, 2018 6:37 pm quote
thanks to Voodoo I noticed I am missing the cowl. Will buy ir from SIP, found a plastic one.
Fri Dec 07, 2018 7:05 pm quote
You can still gently test run it like that, even very short easy rides as long as it doesn't get too hot.
OK, now you've got this coming:
but the flywheel cover is missing here.
I hope you have this piece already.
GS160, V50R
Sat Dec 08, 2018 3:17 am quote
Not correct, as been explained, but actually not a bad idea in my opinion.
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   vespa scooterwest scooter west Motorsport Scooters   AF1 Racing Vespa Austin
[ Time: 0.2638s ][ Queries: 25 (0.0532s) ][ Debug on ]
