SIP rev counter problem
Vespa 100
Thu Dec 06, 2018 1:29 am quote
hi guys, recently i bought the SIP rev counter for my SS90, everything is fine except the speedometer (which is to tell the speed) RPM, and TEMP is working fine.. i change everything, gear on the hub, and speedo cable, but still the speedometer doesn't work.. i try to spin the cable manually using drill in low speed but no reading on the speedometer..
when i 1st time to fit the speedo, the speedometer works even my bike still on the stand and reach 90km/h, but when i try to test drive it it stop working..
already check the wiring, everything was fine.. already contact the SIP but still no response..
1979 P150X, 1983 P200E, 1996 PX200E, 2011 Yamaha Fazer 600 S2
Thu Dec 06, 2018 2:01 am quote
The speedo needle has two functions. It works as a tachometer (engine RPM) or speedometer (Km/h). Have you set it up correctly to work as a speedo??
Vespa 100
Thu Dec 06, 2018 2:14 am quote
yep, i set the needle for RPM now, but if i set the needle for speed it still doesn't work.. thanks for the reply
too many
Thu Dec 06, 2018 4:07 am quote
hi,
Have you checked the input on the speedo?
for the sip speedo there are two available sources for speed, either the normal wire or a electric cable.
Check the menus and make sure it is set on normal speedo wire
Vespa 100
Thu Dec 06, 2018 4:15 am quote
hi again thanks for the reply.. yes already check the input, i already set it in INT (for the regular speedo cable), but i also try the EXT (for the speed sensor).. but it still the same.. still no working.. i never so frustrated as i am right now dealing with this old metal bike
Thu Dec 06, 2018 6:03 pm quote
Are you using a resistor spark plug?
Vespa 100
Thu Dec 06, 2018 9:50 pm quote
no i'm not.. im using regular NGK B9ES.. is that affecting the speedo?
Thu Dec 06, 2018 10:59 pm quote
Yes it does.
vba vespa 210, API monza230
Fri Dec 07, 2018 11:59 am quote
NGK BR9ES
Rallies Europe 2016   vespa scooterwest scooter west Motorsport Scooters   Scooter Parts Company
[ Time: 0.5979s ][ Queries: 23 (0.0985s) ][ Debug on ]
