GTV or GTS for long-term purchase
Primavera 150
Thu Dec 06, 2018 8:38 pm quote
Iím considering a new GTS Super Sport or a slightly used GTV. What do you folks think about the differences between the two? Which one will I be happier with long-term? Are there any real advantages to one over the other?
LX150, GTS300, BV350, EN650
Thu Dec 06, 2018 8:46 pm quote
Differences:
1. Seat style - one piece vs. split
2. Instrument panel
3. Headlight location.
4. Exposed handlebars on GTV (ability to mount stuff there)
Most who have issues with the GTV have issues (it seems) with the split seat. For some, it is just not as comfortable as the GTS seat.
Personally, I prefer the light position of the GTS and the instrument panel as well.
I would also assume resale value may be better with the GTS as it is the more popular style.
If you're able to, ride them both. For most it comes down to styling and seat comfort.
Good luck and hope to see you again soon!
Modded Vespa 2017 GTV 300, BMW 2017 C650GT
Fri Dec 07, 2018 3:38 am quote
Mostly what JP said. Really it's up to you as to which one you prefer. I'm 5' 11" and find the seat comfortable but do at times wish it was a little longer where the rider sits. One advantage of the headlight position is you can stack things higher up on the front rack as the headlight does not get in the way.
I think the GTV is a good looking scoot, here's mine and a pick with a few GTV's with different windscreens. Actually about the only 2 you can get for it. The GTS has more screen options.
Location: Not really sure but I think somewhere in the engineering dept at Starfleet's UK HQ
Fri Dec 07, 2018 4:03 am quote
There's no difference between the GTS and the GTV regarding long term ownership. They are both brilliant. Just make sure to service it according to the factory recommendations and you won't get any problems at all. The engines are good for very large mileages before needing work doing to them (servicing aside of course). Would recommend using proper motorcycle oil of the correct spec (not car oil) if you want best long term reliability and maximum engine life.
Sponsor
Granturismo 218
Fri Dec 07, 2018 12:14 pm quote
Most of the parts that are unique to the GTV will be more expensive than the same part on the GTS, and often require a longer wait, moreso as time goes on.
2010 Vespa GTS 300 ie Super & 2003 Honda Shadow VT750 ACE (sold) & 2006 Vespa LX150 (sold)
Fri Dec 07, 2018 12:24 pm quote
Itís the saddle. Longer distances may prove limiting and ultimately pain inducing. If you like the overall look of the GTV, you can get the best of both worlds by picking up a GTS saddle and swapping it out for longer rides.
2014 GTV 300ie
Fri Dec 07, 2018 1:10 pm quote
That's what I do. Have a solo gel seat that I swap out for longer trips and just to change things up. I am 6'2" and both seats are comfortable. Just a matter of taste and if you want the FASTER GTV!
2014 GTV 300ie
Fri Dec 07, 2018 1:12 pm quote
Yikes, just realized I have 666 post... posting here to change that! Whew! That was close...
Fri Dec 07, 2018 1:24 pm quote
That makes the GTV devilishly fast
Sat Dec 08, 2018 1:59 am quote
I'm praying for your soul....
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   Vespa Wasp Pin Badges   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.8696s ][ Queries: 25 (0.1338s) ][ Debug on ]
