Rear brake pad replacment on mp3 500
Fri Dec 14, 2018 7:03 am quote
For everyone else on here that has done this job.
I feel your pain.
OMG couldn't they have made it a bit more difficult if they tried.
Piaggio MP3 250, BigBeo
Fri Dec 14, 2018 8:52 am quote
Can you tell more? I guess my BigBeo's brake caliper is located same way on same place, but I see no problems...
MP3 500
Fri Dec 14, 2018 10:29 am quote
Which screws did you take off??
I need to do this on my 2009 MP3 500 and tried once, but put it off till after Christmas.
In the book it shows two screws outside of the two screws that hold the pads in place, but mine does not have them there. That would have been just to easy I guess. I could have just started taking off all the bolts until I got the right ones, but my experience with this method has caused me much grief!
I have changed these pads on my old 2009 MP3 by forcing the new pads back up into the caliper without ever removing it. I don't want to go through that a second time.
Wed Dec 19, 2018 3:35 am quote
You need to take the exhaust off. Side of the rear swinging arm to allow the wheel to come off.
Then air-box mounts need to be loosened to allow access to the caliper mounting plate.
Compared to the front its a bit of a ball ache. Just to replace pads.
A handy person could do it, just quite a bit to be done.
I found using the foot peddle as well as brake lever helpful to get a good bleed.
Wed Dec 19, 2018 3:41 am quote
Ah, yep, the airbox... it is under the topcase in my Beo. Instead I have to remove the front wheels to replace the pads on mp3 250. The calipers can't be removed from brake disks if the wheels are on their places.
Thu Dec 20, 2018 4:43 am quote
Just to mention.
Be very careful when refitting the wheels the torque required is very low as the hub material is very soft and easy to strip the threads.
Thu Dec 20, 2018 9:32 am quote
Refitting wheels is the best reason to buy a torque wrench
Fri Dec 21, 2018 12:02 am quote
Re: Rear brake pad replacment on mp3 500
There are two pins with Allen key heads that retain the pads but to get the new fat pads into place the caliper will need to be removed from the disc.
I removed the two bolts that are held in place with bent over tab washers these hold the caliper mounting plate that also holds the parking brake caliper.
MP3 500 LT
Fri Dec 21, 2018 4:07 pm quote
Here is a tip from an old Mechanic. Take a small Hammer (Preferably a Nylon Hammer used for mounting bearings, pins, waterplugs etc.) and tap the Brake Caliper lightly meaning not too hard gut hard enough to nock out any rust or dirt that will definitly make it hard to remove the pads. That should make the Job a wohle lot easier.
MP3 500
Wed Dec 26, 2018 7:44 am quote
Thanks Brasseye,
I am planning on taking a look at this Saturday 12-29-18
I have a slight Oil leak (motor side) and I will try to fix the break and leak at the same time.
Also see if I can get a picture of the caliper for others that will have to change the rear pad.
The leak isn't bad and isn't coming from the air filter. I will have to clean it up to see if I can locate the source.
Wed Dec 26, 2018 10:28 pm quote
Ask me if you find that crankshaft oil seal is leaking. I've fixed that on my BigBeo with Master 500 recently.
2019 Spring Gathering - May 16 - 19, Location TBD (Likely Maggie Valley, NC)   Vespa Wasp Pin Badges   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1528s ][ Queries: 23 (0.0334s) ][ Debug on ]
