What is a crank pin made out of???
2003 Derbi bullet 2 stroke
Thu Dec 27, 2018 10:23 pm quote
Need to get a custom one made so what should it be ? Was thinking titanium but I read it is expensive and wears fast so that's out of the question.
P 200E P125X
Fri Dec 28, 2018 3:52 am quote
I would guess a tool steel alloy that would be case hardened and ground to the correct diameter.
Fri Dec 28, 2018 4:41 pm quote
https://worb5.com/EN/crankshaft-connecting-rod-racing-crankshaft-connecting-rod-heave-dynamic-laser-vespa-lambretta.html
Worb5 wrote:
Customized eccentric crank pins
It is possible to start eccentric crank pins for different crankshafts. For this purpose, the crankshaft must be disassembled, the crankpin dimensions determined and calculated. A production drawing is created. The crank pins are pre-machined from an insert steel, then surface-hardened and finally ground.
Rallies Europe 2016   vespa scooterwest scooter west Motorsport Scooters   Cool Ass scooter seat cover
[ Time: 0.1775s ][ Queries: 23 (0.0603s) ][ Debug on ]
