Hazard lights stay on
Piaggio MP3 250
Mon Jan 14, 2019 4:07 pm quote
Just purchased an MP3 250 that has sat for 2 years. The seller put a new battery in and changed the oil and informed me the tilt lock quit working. Anyway I trailered it home and will look into the tilt lock problem later, but today I drove it down the block and back into the garage and when I got to the garage the hazard lights went on and won't go off. Even with the key removed. Any help is appreciated I did a search and checked the manual with no success.
Piaggio MP3 250
Mon Jan 14, 2019 4:50 pm quote
Never mind. I just discovered that they can be turned on 2 ways. One by pushing the hazard switch off and on, and the other way by pushing in the turn signal switch. Now that makes zero sense to me. What's wierd is if you accidendently turn them on with the direction switch they won't turn off by pushing the hazard switch, only by pushing the turn signal switch again. That doesn't seem right, anyone else have this issue?
2008 MP3 500, 2013 BV350
Tue Jan 15, 2019 10:35 am quote
That should not happen, may have a bad switch.
Rallies Europe 2016   Vespa Wasp Pin Badges   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.2381s ][ Queries: 23 (0.0527s) ][ Debug on ]
