oil dipstick
GTS 300
Mon Jan 21, 2019 12:08 pm quote
Saw ROBOT install some aluminum mods and one was the oil dipstick. It's tamper-proof requiring the Allen wrench to remove. I like the idea that no one can mess with the oil. Are there less costly alternative oil dipsticks around?
Ralph
2008 MP3 500, 2013 BV350
GTS 300ABS, Buddy 125, Typhoon 125
Sat Jan 26, 2019 10:25 am quote
That is the less expensive one!?!
LX190
Sat Jan 26, 2019 2:24 pm quote
People messing with oil is a thing?
GTS 300
Sat Jan 26, 2019 2:52 pm quote
I dunno, people will mess with anything. Especially something with a turn knob.
2006 Vespa GT (Rocket): 2005 Vespa GT (Razzo): 2007 Vespa GT (Vanessa): 2009 Yamaha Zuma 125 (Zoom): 2018 Yamaha Xmax (Max),
Sat Jan 26, 2019 3:15 pm quote
I have never had an issue with oil tampering in many years of scooting in many states and countries.
Sometimes people make up problems. Not sure why.
Bill
Sat Jan 26, 2019 4:12 pm quote
I have enough trouble messing with my own dipstick....as in losing not one, but two. Maybe I need an ignition interlock or something.
Sat Jan 26, 2019 5:08 pm quote
I've always heard you are not supposed to do that!
Sat Jan 26, 2019 5:22 pm quote
Could explain my vision problems.
Lx 50 4T, S 150, GTS 250
Sun Jan 27, 2019 8:43 am quote
crossed thread
2014 Commuter BV350(40,000)/2015 Scoot Life BV350(9,000)/2010 El Diablito SH150i(28,000)
Sun Jan 27, 2019 11:28 am quote
Bill
Try living in an apartment complex and owning a bike.
Buddy Pamplona 50cc, Vespa GTV 250ie
Sun Jan 27, 2019 11:45 am quote
I suppose it depends where you live. Iíve dealt with some incredibly obnoxious and creepy people in the St. Louis area simply because I was riding a scooter. I have no idea why it bothered them. I ride at the speed limit or slightly abound, I wear a jacket that I can be seen in... but certain types just take exception to a person on a scooter. I did have to have my fuel hose replaced month due to someone slashing it, and much more recently, Someone keyed it right down to the bare metal while I was at work. So though I never have heard of anyone messing with the oil, I wouldnít put it past certain people in certain areas.
My take on it is if you really feel
Like itís a possibility, do what you need to do to avoid it.
Sun Jan 27, 2019 11:52 am quote
Just here in Kansas all the pick up trucks. And if it is wet and rainy and don't give a s**t when they splatter you and the scooter with crap.
Sun Jan 27, 2019 12:08 pm quote
I hear ya. Thatís who the jerks usually are here. Usually from the south side and usually old, slightly beat up pick up trucks, usually black. Never silver or red. Almost always painted black. Why I donít know but scooters really seem to get make them get their hackles up.
LXV 150 Midnight Blue (Sold)
Sun Jan 27, 2019 5:44 pm quote
Re: oil dipstick
Drill a hole in the oil filler cap and wire it on like racers or aircraft?
[img]www.cornerspeed.net/2014/images/WireOilFill.jpg [/img]
[img]www.sportrider.com/sites/sportrider.com/files/styles/500_1x_/public/import/page_element_images/146-0002-04-z%2Bsafety_wiring_techniques%2B.jpg?itok=XNXvThzs[/img]
Sun Jan 27, 2019 7:41 pm quote
Sorry about the pictures they work in my browser but not on MV
GTS 300
Mon Jan 28, 2019 9:18 am quote
Re: oil dipstick
Was able to review the pictures of the braided wire through small holes. This doesn't appear adequately tamper resistant.
Storing an Allan wrench under the locked seat is looking like a good option. The ready made is costly probably due to the spun aluminum design. Wonder if I can fashion a change with Mr. Dremel; cut off the tab and screw, melt or glue in an Allan nut head.
Mon Jan 28, 2019 9:23 am quote
Re: oil dipstick
You'd want to not leave enough of the plastic dipstick exposed so that it could be turned with pliers.
A "security" screw head might add a bit of extra security, over a plain hex socket.
GTS 300
Mon Jan 28, 2019 9:30 am quote
Re: oil dipstick
While brain storming I think putting a head into the dipstick cover that matches one of the tools in the kit is better since the tool kit is secured in the locked glove-box.
Mon Jan 28, 2019 10:13 am quote
Are you putting them in as attachments lower on the page, or pasting a link?
GTS 300
Mon Jan 28, 2019 11:21 am quote
Re: oil dipstick
What is a security nut? I viewed some grub nuts with a hex head that I could screw and epoxy into the dip.
Mon Jan 28, 2019 11:37 am quote
Re: oil dipstick
also known as tamperproof.
Variations include Allen (hex) socket in addition to Torx like this picture. There are other variations that have a pattern of three holes in the head, etc.
The post in the center of the socket prevents an ordinary driver from fitting. But it's only a little bit of added security. "Tamperproof" driver sets are readily available about anywhere.
GTS 300
Mon Jan 28, 2019 1:19 pm quote
Re: oil dipstick
These tamperproof would be a suitable solution. I'll need a female side able to withstand inch pounds of force from my manual hand held driver.
Mon Jan 28, 2019 5:05 pm quote
Re: oil dipstick
[quote="RP Tech"
[/quote]
We are talking tampering here. None of the options will be tamper proof if someone really wants to mess with your oil.
They will simply study your set up and come up with the tool in question. If you can buy it so can they.
I thought you wanted to stop opportunists. Any serious criminal mind will find a way.
Put a drop or two of bright nail polish on the joint between the dipstick and the engine case. It won't stop anyone but will tell you if anyone has unscrewed it.
Tue Jan 29, 2019 4:43 am quote
For that quality I think that's affordable
Tue Jan 29, 2019 5:32 am quote
If you are thinking of glueing something to the dipstick, that may not be possible depending on what it is made out of.
Tue Jan 29, 2019 6:33 am quote
And if you do glue a screw or bolt into a dipstick, it might be a good idea to cut a slot across the end of dipstick before you glue the screw in. That way you could use a large screwdriver in the slot to remove the dipstick in case the screw comes out with the stick still in the engine.
Tue Jan 29, 2019 6:41 am quote
Ok, now anybody have a 3-D printer?
Tue Jan 29, 2019 8:16 am quote
I thought I was the most paranoid here now the stick. One story that is hard to believe but it is true is that one day i left the GTS unlocked downtown and some pump(s) pour sugar in my tank. That was very expensive to replace. But I understand you I don't want any thing to happen to your oil. The smallest attempt to temper with it would be biblical.
GTS 300
Tue Jan 29, 2019 10:16 am quote
That's the ticket!
Remember I'll cut off the thumb tab to screw-in the tamperer-proof grub nut.
Like JKJ-FZ6 idea for a slot, just in case.
Tue Jan 29, 2019 1:08 pm quote
oppsclunkthud has one.
Tue Jan 29, 2019 6:45 pm quote
But if determined you could still unscrew the cap with miniature vice grips?
BMW has some slick items for their oil filler on boxer engines
Tue Jan 29, 2019 6:51 pm quote
Drill a hole through the OEM filler plug.
Put a suitably long one of these through the hole
Then put a miniature padlock from Walmart, through the clevis pin
The length of the clevis pin means the filler cap cannot easily be unscrewed
Sponsor
Granturismo 218
Thu Mar 07, 2019 8:51 am quote
The Rizoma Dipstick is tamperproof, an OEM Piaggio Genuine Vespa Accessory, and it tells you that's where the Oil goes.
https://scooterpartsco.com/recambi-scooter/rizoma/oil-filler-plug-bolt-aluminum
GTS 300
Thu Mar 07, 2019 10:18 am quote
Thanks Motovista. We already knew about the Rizoma and was seeking a Do It Myself version.
Sponsor
Granturismo 218
Fri Mar 08, 2019 12:47 am quote
Cut the top off and carry a pair of pliers.
Missouri Loves Company Rally   Vespa Wasp Pin Badges   Cool Ass scooter seat cover
[ Time: 0.3966s ][ Queries: 25 (0.1044s) ][ Debug on ]
