Stella 150 temp/tach gauges and a cell phone charger
1980 P200E project, 2005 Stella Malossi 166 MKIII
Mon Feb 04, 2019 10:07 pm quote
Wanted to get this done before doing my first engine rebuild and upgrade/case matching of a bigger cylinder head. Have been too busy at work to start the larger project, so this was a small and easy project that I could work on over the past month while work was busy.
Gauges mounted flush with the headset to fit snug below the stock speedo. Wires not sent through the frame, but hidden along the crash guards and fed through a grommet at the top of the horn cover. Some day i'll feed them through the frame properly. Everything fit just barely under the horn cover, with some effort.
Knock off ram mount with usb charging port from wish.com. (5a inline fuse not pictured).
Koso gauges off eBay.
Mon Feb 04, 2019 10:09 pm quote
Completed setup..
I also moved the wire taps from orange to the horn gray wire, just cause it was lower down in the horn cover with more space. In total, I added 4 spare power connections +/-, used 3 on Koso DL-01T, Koso DL-01R and knock off ram cell phone mount with inline fuse. One spare set of connections, probably will never be used. Previously, all the DC bulbs were switched to LED which freed up a ton of power. The battery is always at full charge, battery tender never charges for more than a minute when plugged in.
Cross Egypt Challenge - A 2400km ride throughout Egypt   vespa scooterwest scooter west Motorsport Scooters   Scooter Parts Company
[ Time: 0.2632s ][ Queries: 25 (0.0350s) ][ Debug on ]
