the dark art of shimmimg
Old douglas ..smallie with polini 115..super with nasco 177
Wed Feb 06, 2019 11:42 am quote
what would the symptoms be if a super gear box is shimmed is TOO TIGHT??
Wed Feb 06, 2019 11:49 am quote
it'll be really really tight and difficult to turn over by hand. running, it'll whine and be difficult to shift with the possibility of moments of gear clash between the tree and the next gear resulting in a terrifying grinding sound.
at least in my experience.
-g
Thu Feb 07, 2019 11:53 am quote
sorted
Sweetbix bro.
Twas not the shims that were too tight..ended up the outer cable for the gear was riding on the adjuster.....the cable at the back that pulls first from neutral is hard to see......nice and tight when it was set..then when you pulled it into 2 3 and 4..the cable in questionwould go too loose and you could no longer get it into first.
Established this by pulling the gear elector box completely off....and then turning the handle and watching the bat wing go back and forth (or not) ..was also I nice way of setting the cables so the neutral dot lined up.
Fckn scooters
2019 Fall Gathering - September 12 - 15, Hungry Mother State Park, Marion, VA   vespa scooterwest scooter west Motorsport Scooters   Cool Ass scooter seat cover
[ Time: 0.2386s ][ Queries: 23 (0.0219s) ][ Debug on ]
