1978 VBC wiring harness installed - helpful trick
2008 LX 50 & 1978 150 Super
Thu Feb 07, 2019 5:22 pm quote
Just a quick note on a trick I used while installing a new harness. I did have the headset off and tank out. The veterans probably have a better way. I attached a spare wire to the main batch of wires going to the headset and a separate one attached to the horn and a separate one for the brake. When I pulled out the old harness these wires came back through the frame. Next I attached the new harness to the wires and pulled the new harness sections to their respective holes.
Now someone can tell me what I should have done. Thanks for listening.
1960 Series 2 Lambretta, 1962ish API series 2 Lambretta, 1974 Vespa Super 150, 1978 Rally 200
Thu Feb 07, 2019 7:51 pm quote
I also did exactly that when I replaced the harness on my Super. Made the job reasonably easy. I saw it done on a video somewhere. Thumbs Up!
Sun Feb 24, 2019 6:23 pm quote
Drag thru a few bits of string while threading loom... then in the future if you ever need to add something, just tie it is & pull it thru.
Also, add 2-core (beefy, sheathed stuff) & 5-core trailer flex, then there is heaps of colour coded wires ready to go.
Thu Mar 21, 2019 11:59 am quote
me too
Fri Mar 22, 2019 3:38 am quote
Original post
Fri Mar 22, 2019 5:38 am quote
Done!
I searched my ongoing post "ode to Speedy" & found the following idea & explanation for wiring a VBC. Hope it helps
Fri Mar 22, 2019 5:44 am quote
Thank you for the information. The weird point is that “Babu” cut and pasted my original post.
Your Rally Here   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.4409s ][ Queries: 25 (0.0554s) ][ Debug on ]
