old fuel..6 months old..what effect ?
Old douglas ..smallie with polini 115..super with nasco 177
Mon Feb 11, 2019 12:00 pm quote
Hi Pulled a scoot out the corner of the shed that was put away running about 6 months ago.
It started easily.idles nice.....but just will not rev out...scoot gets to about half its normal speed on the open road and wont go any faster.
Cleaned carb. new plug......with exactly the same symptom after so logic says its not those.
Brakes are NOT stuck on
Could it be the old gas?
Mon Feb 11, 2019 12:25 pm quote
Could be old gas...and could be mice in the air filter.
Mon Feb 11, 2019 1:03 pm quote
...or in the muffler.
1955 Allstate 1958 lambretta 1965 Allstate 1968 sprint
Mon Feb 11, 2019 1:06 pm quote
Fuel issues
My guess with no other info....would be water in the fuel. Siphon out the old and put in some new fuel. Easy and quick. Scott
74 50s x2 78 P200 84 Cosa 58 AllState 68 Sprint 80 50special + projects
Mon Feb 11, 2019 2:35 pm quote
Good call. Check it out to be sure it's clear. Shouldn't be a problem unless there's dino 2T oil in the past. A sludge or, I suppose, mouse clogged muff will give you the symptoms described - idles OK but won't wind up.
Mon Feb 11, 2019 3:57 pm quote
Either way, whatever the cause, stop wondering and siphon out the fuel. you can put it in your car or truck that has a large fuel tank and use it up that way. Gasoline starts turning to varnish in 3 months without a fuel stabilizer added.
1976 Super (x 2), 1974 Primavera (x 2), 2006 Fly 150
Mon Feb 11, 2019 5:42 pm quote
Does it rev out on the stand? Is the slide opening all the way?
2019 Fall Gathering - September 12 - 15, Hungry Mother State Park, Marion, VA   vespa scooterwest scooter west Motorsport Scooters   Cool Ass scooter seat cover
[ Time: 0.1766s ][ Queries: 23 (0.0214s) ][ Debug on ]
