Lml issues
Lml with 166 malossi kit
Mon Mar 11, 2019 10:29 am quote
Hi all, I have an lml 125 2 stroke with a 166 malossi kit.i have a px Maz comp crank fitted, it's running idle jet 4-140,a BE4 mixer tube atomizer and a 190 air corrector jet. The carburettor is still the standard SI type. And a polini race exhaust...I'm looking to you guys for your input as to why the bike seems to run poorly ie almost as if it is on full choke when you 1st pull away...but suddenly clears and pulls like a train....is this normal ?...is it the point where the power band is ? While on a long run the engine doesn't miss a beat and accelerates beautifully, it's only when you stop and then go to pull away again that the bogging appears.im very new to the scooter scene so please treat me as a novice.i really would appreciate any points in the right direction.Thanks Roy
'01 ET4; '65 VBB Restomod with P200E engine, '67 VW Type 1, '80 Airstream
Thu Mar 14, 2019 7:50 pm quote
Re: Lml issues
That was normal for the the LML 150 engine I am replacing with a restored P200E engine but it's not supposed to be normal......and timing was the only thing i could never check due to damaged crankshaft threads.
Check timing and be careful with those threads.
73 & 74 Rally, 76 ET3, 80 P200, 06 PX150, 61 Ser 2, 65 Silver Special, 86 & 96 Elite 80s, 2015 HD Road Glide Special, 2011 Ural Tourist
Thu Mar 14, 2019 9:54 pm quote
See if you can find a moderator to move this to the Not So Modern forum section. Lots more chat about kitted 125 motors there.
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   vespa scooterwest scooter west Motorsport Scooters   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1180s ][ Queries: 25 (0.0319s) ][ Debug on ]
