Pinasco master cases
'01 ET4; '65 VBB Restomod with P200E engine, '67 VW Type 1, '80 Airstream
Sun Apr 07, 2019 6:49 pm quote
I thought I read somewhere that there are problems with these cases? anyone know?
1979 Vespa P200E
Mon Apr 08, 2019 12:55 am quote
cool but that didn't answer the question
1979 P150X, 1983 P200E, 1987 T5, 1995 PX200E, 2011 Yamaha Fazer 600 S2
Mon Apr 08, 2019 5:12 am quote
Yes. There have been many reports for poor quality. They are cast in Asia. So far Iíve seen a few with air leaks in the statorís threads, FMP posted a video a while back (Pinasco asked him to take it down) where the crank bearings nests were shot after a couple of thousand Kms and Iíve seen two cases where they had pores on the machined surface of the flywheel seal. I would also go for the Malossi. They have a rotary valve version as well...
Sun Apr 14, 2019 8:56 am quote
25+hp engines with Pinasco master cases?
Amazing to me that these apparently expert engine builders use pinasco cases if they are problematic.
https://www.vespmoto.de/shop-english/engines/
Sun Apr 14, 2019 7:11 pm quote
Re: 25+hp engines with Pinasco master cases?
I wondered about his motors as well. Presumably he buys that many that Pinasco takes back any dodgy ones... who knows how many out of the production are not good?
I think that buying Malossi is pretty much a guarantee of quality, they are a long way ahead of the competition... they should last a good many years. I know you're not asking about the Malossi ones but with your investment to date, it might be the wise choice.
Mon Apr 15, 2019 1:34 pm quote
Holy smokes I bet that was a fun problem to chase
1974VLB 1979VSX 1974V9A
Mon Apr 15, 2019 7:58 pm quote
Pressure tester and a spray bottle of soapy water. I would have been lost forever without these.
PX 200
Sat May 11, 2019 8:01 am quote
Iíve tried both malossi (old one, not the VR) and Pinasco...
Hit and miss on both...
The malossi was still cast pretty badly, I feel like it was a reject off the Piaggio factory, the aluminum was rough, pitted and protrudes everywhere. And you still have to use the JB weld on the walls near the cylinder.
My Pinasco faired better, bearing surfaces seemed ok, but Iíve heard the stories of bad cases too. The aluminum is much harder, found out when porting the cases...
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   Vespa Wasp Pin Badges   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1555s ][ Queries: 25 (0.0497s) ][ Debug on ]
