Can’t live without you! Favorite tools
bare metal cafe racer
Mon Apr 08, 2019 12:35 am quote
Hey all. Was thinking a thread about the (behind the scenes) tools that keep these beauties ticking over would be interesting. The unsung heroes!
As you can see, I am a Ryobi fanboy. Solid entry-level kit for DIY. Rarely disappointed by their products.
Randomly, the tool I choose to share is the cheap as Ryobi wet and dry workshop vacuum. Actually bought it to connect to a vinyl record cleaner (that works crazy good). But this vacuum has taken years of punishment, cleaned up many spills (beer, slushies, dog food to name a few), and never missed a beat. Keeps the tiny workshop bearable. And bagless so no ongoing running costs. Also can easily find that really important piece you just sucked up - just make sure you emptied the dog food and gave it a clean before you go there...
bodgemaster
1963 GL, 1976 Super (x 2), 1974 Primavera (x 2), 2006 Fly 150
Mon Apr 08, 2019 6:04 am quote
The Big Four:
8” flat blade
1/4” T handle spinner
Long curved needle nose
Headlamp
Use at least 2 of these on just about every scoot fix
2006 GT200L "Lone Star"
Mon Apr 08, 2019 11:22 am quote
Three Things
I was military and civil service and moved a lot. My shop stuff had to be portable and storable.
The Workmate is going on 40 years old and still works fine.
The Keter table is lightweight but strong and folds flat in my crowded garage.
The Vise Grips because few other tools represent both repair and destruction so effortlessly.
And yes, I replaced the nearly new Shinkos in the background with City Grips a week ago.
Mon Apr 08, 2019 11:42 am quote
SoCalGuy wrote:
The Big Four:
8” flat blade
Headlamp
Headlamp - check
I got decent pliers including needle nose but not curved. Can see curved would be useful.
Why such a long flat?
And what’s the use/advantage of the T handle over a socket? Speed?
Mon Apr 08, 2019 11:46 am quote
Dammit - this thread is awesome and wish I’d started it a long time ago. That Keter would have solved a lot of my space (lack thereof) issues. Plus the portability...
GTS 300 Super
Mon Apr 08, 2019 1:04 pm quote
No one said Beer nor 10mm wrench.
Disqualified thread!!!
1964 GS160, 1966 90ss, 1976 Sprint Veloce
Mon Apr 08, 2019 1:32 pm quote
If you can claim a shop-vac I'm going to claim this. I was troubleshooting my dead 6V AC horn this weekend. I needed an AC source on the bench. Radio Shack is history, so I dug this out.
20 minutes later the horn was quacking.
Mon Apr 08, 2019 2:05 pm quote
10mm
Good call on 10mm combo wrench/socket. Pretty much can't work on European or Japanese stuff without one
bodgemaster
Mon Apr 08, 2019 2:29 pm quote
Yeah, T handle's simple and fast, length minimizes bashing paint and scraping knuckles, no fumbling around for extensions, enough leverage for head bolts, tank bolts, wheels, exhaust.
Long slotted w/narrow cabinet tip allows ez access to SI carb mix screw, carb lid screws, air filter, jets, etc. Good for setting points and prying stuff too.
Mon Apr 08, 2019 3:04 pm quote
Dude - that is from a Lionel train set I had growing up. Seriously haven't seen an image of that since bell bottoms were in. Awesome.
Mon Apr 08, 2019 3:14 pm quote
There isn't very many things on a older Vespa that uses a 10mm. Maybe removing the foot brake?....i can't remember. The ironic thing is that my KTM dirt bike has only one thing that uses a 11mm, and i think it was a hydro banjo bolt or somthing.
Mon Apr 08, 2019 8:08 pm quote
Metrinch 5mm(3/16) - 12mm (15/32) universal 1/4' drive 8 pce socket set with ratchet, extension and swivel.
Geezer goggles
Most all else can be bought in whatever country I find myself.
Mon Apr 08, 2019 9:12 pm quote
Measure once.
Grind twice.
Mon Apr 08, 2019 10:12 pm quote
charlieman22 wrote:
Measure once.
Grind twice.
I have Dremel envy. Thinking my Ryobi can't hold a candle to that...
OMG the tungsten router bits for it are $$$??? What bits do people use?
1978 MotoVespa 160GT, 2009 LML Star 150 2T (Stella), 1961 Lambretta S2, 1962 Lambretta S3, 1964 Lambretta J100
Tue Apr 09, 2019 2:01 am quote
My vote is for the Bahco SL25 1/4" drive socket set. I add some more useful screwdriver bits and a 14mm socket in place of the torx bits.
It's the most-used item in my garage - as it's so small, I also keep a set in the glovebox of all my scooters.
a not so normal vbb2 '64, a weirdo vbx '86 and a not so normal pts100 '82
Tue Apr 09, 2019 3:49 am quote
A plier (2 of them) and a screw driver.. mostly thats all i need there a moment decades ago when i have to split engine with a plier and a spark plug tool that have 11 and 13 bolt size in both of the end beside the 19 size for spark plug dont ask the result as i ended up damage most of bolt in engine but its still useable somehow
Tue Apr 09, 2019 3:56 am quote
charlieman22 wrote:
Measure once.
Grind twice.
With my Dremel I mostly use the cutoff disks like the one shown in the picture. They'll cut steel, sheet metal, cables,...
ET2 2004
Tue Apr 09, 2019 5:34 am quote
I've got that set too, use it all the time and it goes everywhere with the scooter because it's so small as you say. Nice quality for the price
I can't live without this mini worklight/torch. Only cost £3 and has a strong magnet on one end so will stick to the scooter while I work and is only about the size of a marker pen and very bright. Bargain.
GS160
Tue Apr 09, 2019 5:44 am quote
My fav is the lifting table. If that doesn’t count as tool my springhook applies.
The table helps this spineless creature extensively and the hook saves a lot of bad language.
'01 ET4; '65 VBB Restomod with P200E engine, '67 VW Type 1, '80 Airstream
Tue Apr 09, 2019 6:15 am quote
My favorite tool by far right now is my old pointer type torque wrench!
PX210 Polini, SIP Road 2
Tue Apr 09, 2019 8:13 am quote
Black & Decker Power file. Because nowt ever fits
Tue Apr 09, 2019 10:34 am quote
charlieman22 wrote:
Measure once.
Grind twice.
https://www.amazon.com/gp/aw/d/B00Y01TJ6G/ref=cm_cr_arp_mb_bdcrb_top?ie=UTF8
Bigger. Better. Cheaper.
74 50s x3 78 P200 84 Cosa PK50XL2 58 AllState 68 Sprint 80 50special '66(?) Super125
Sun Apr 14, 2019 6:05 am quote
The first ones I grab for scoot work are these cheapo T handle long sockets, 10mm, 11mm & 13mm.
Not far behind are my 7/8mm , 8/10mm w/ ground down to the minimum heads & 10/11mm thin head open end wrenches.
The wrenches travel with me along with a few other small tools I don't want to be without.
We have a leather pouch, a tapered hand reamer, Phillips+ 1/4" & 3/8" drives, drill reamer w/ countersinks & car bide burr, the wrenches, metric thread file, thread gauges & feeler gauge, hardened extended screwdriver bits, telescoping magnet, thin needlenosers, center punch, pencil beam flashlite, small prybar, copper chunks for backing up welding thin sheet metal, small tape measure, LED test lite, solder, inflating needle for soccer balls and my trusty calipers. A lot of tools in a small bag!
Sun Apr 14, 2019 4:05 pm quote
Pre-1954 cog removal tool.
Sun Apr 14, 2019 8:00 pm quote
remove some cogs do you?
that's epic
Fri Apr 19, 2019 12:03 am quote
charlieman22 wrote:
Measure once.
Grind twice.
Yes... yes they are.
Fri Apr 19, 2019 6:54 pm quote
Pheas' - Yeah nah... of course.
V oodoo- Love the 10-11 from BMW trunk tool kit...
Sat Apr 20, 2019 1:09 am quote
Had fun with this today. Not my shed... one of dad’s workshops (he has like 4...)
Sat Apr 20, 2019 1:10 am quote
In action. Not the most precise / newest of lathes... but got the job done...
P200 PX150
Sun Apr 21, 2019 6:03 pm quote
I would go with the Haynes Manuel and my Picquic screwdriver. (Thanks Canada!)
The manuel bc I have used it more than anything else and the Picquic bc from Phillips to Flatheads it is just a solid and reliable piece of gear. The one pictured is a “mariner” and is corrosion resistant.
It sat underwater for a few says in hurricane harvey... and unlike 90% of my other gear that got soaked you would never know.
'76 Vespa Rally 200
Tue May 07, 2019 3:33 am quote
Other folks have already hit some of the highlights, but here are a few of my favorites.
Wheel hub holding tool, makes removing and torquing the hub nuts easier.
24" long 1/2" breaker bar.
Flashlights. The CAT one has a magnet at the end, good to hold the light where I want it.
This is the best. Street sweeper bristle with a 90 degree bend at the end. Can't count the number of times I've reached for this. It's really good for popping grommets into place, for example.
'63 VBB2T - '76 Sprint V. - '86 PX200E - '18 300 GTS Super Notte
Tue May 07, 2019 4:14 am quote
charlieman22 wrote:
Measure once.
Grind twice.
This made me decide to get off work early to go and get a Dremel. Thans!
64 Allstate 62 Vbb 64 Li 77 Et3
Tue May 07, 2019 9:18 am quote
i have the same workmate, it comes in handy for so much and is super low profile. Mine was my grandpas and when he passed I received it. Guessing it’s about forty years old too.
Rallies Europe 2016   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.2362s ][ Queries: 25 (0.0354s) ][ Debug on ]
