Piaggio MP3 500 with J.Costa Variator
Piaggio mp3 500 2015
Tue Apr 30, 2019 12:31 pm quote
Hello, who have installed J.Costa Variator?
MP3 250 & T Max
Wed May 01, 2019 6:08 pm quote
I did. Much better performance over standard variator. Then so are Dr Pulleys.Which I am back to using.
Thu May 02, 2019 4:58 am quote
Maybe you remember how many rpm engine have on 50km/h or similar. Because my one is around 6000rpm and its coming some noisy sound from variator. And maybe you know how many grams weihgt are in your J.Costa variator
MP3 250 & T Max
Fri May 03, 2019 10:52 pm quote
The weights wouldn't be of help to you as I fitted it to my T-Max. Although it is 500cc engine characteristics are quite different. The J Costa had the 'bullets' changed every 20k along with the belt. About 50k it began to give trouble,felt like a slipping clutch. I replaced the bush and the sliding pin-expensive- and no lasting improvement. The bell checked out OK. Maksor advised Dr Pulleys, so the original variator went back in with the good Doctors product. I've been very happy having made the change.
LXV 150 Midnight Blue (Sold)
Fri May 03, 2019 11:18 pm quote
Karpinskis wrote:
. And maybe you know how many grams weight are in your J.Costa variator
They should be 22 grams and there are 14 of them.
JC16031022014MB
How many kms on your variator? Maybe you need some new weights?
Well that's a surprise.
Gilera Fuoco 500ie
Sat May 04, 2019 10:15 pm quote
Well i've tested all Malossi, Polini, Power+, Tech pulley and the JC
Don't like the way a Jc react its more on/off not as smooth
a JC is the one of the 2 that does not wear out as much as malossi or Polini
Sun May 05, 2019 10:13 am quote
JC16031022014MB
weight is 19g on my variator so maybe is to lights for abs version
Sun May 05, 2019 10:14 am quote
Sun May 05, 2019 10:15 am quote
Karpinskis wrote:
weight is 19g on my variator so maybe is to ligh for abs version
2019 Fall Gathering - September 12 - 15, Hungry Mother State Park, Marion, VA   Vespa Wasp Pin Badges   AF1 Racing Vespa Austin
[ Time: 0.5045s ][ Queries: 23 (0.0616s) ][ Debug on ]
