LX 150 no start 2007
GTS250ie
Mon May 06, 2019 3:39 pm quote
2007 LX 150. It will crank but not start. I cannot get a sign at the input wire to the coil. Where is the ignition control unit? Any good tips on how to diagnose? Same for the pulse generator coil. Any easy access to the wiring for these two parts?
A year ago, it quit running on a ride, for no apparent reason, but restarted.
2004 Vespa 150
Mon May 06, 2019 5:08 pm quote
Re: LX 150 no start 2007
I am by no means a vespa expert, but I can tell you mine was doing the same thing until I cut the hose to the evaporations system. Was cranking, but would not start, would die if it did start. Since cutting hose, it has started and ran every time and has not died. Fingers crossed.
Missouri Loves Company Rally   Vespa Wasp Pin Badges   AF1 Racing Vespa Austin
[ Time: 0.1564s ][ Queries: 23 (0.0203s) ][ Debug on ]
