old hands need new clutch..devolution
Old douglas ..smallie with polini 115..super with nasco 177
Thu May 09, 2019 12:56 pm quote
at 52 its getting harder to pull the clutch handle in.....all because of stronger springs, 4 plates. banded baskets 22 teeth that I installed through my 40s to harvest power from the tuning bug
Twas thinking of devolution using a stock standard clutch and springs in a dr177 tune and then thought someones had prob done it already
will it slip?
1979 P150X, 1983 P200E, 1987 T5, 1995 PX200E, 2011 Yamaha Fazer 600 S2
Thu May 09, 2019 1:21 pm quote
COSA II clutch, 4 stock springs & 4 SIP "L" springs, CR80 plates and it's like butter on my Ratty longstroke PX200. If you want to take it further, the MRP "adjustable" actuator will help even more...
1979 P200e
Thu May 09, 2019 2:59 pm quote
OK, first thought that popped into my head....
Are we not men? We are DEVO!
Which actually stood for de-evolution
[img]http://stmedia.stimg.co/ctyp_devo_press.jpg?w=800[/img]
Thu May 09, 2019 3:22 pm quote
DR177 does not need anything but a stock, 6 spring clutch. It will not slip.
2006 px125
Thu May 09, 2019 3:24 pm quote
https://beedspeed.com/products/vespa-clutch-easy-clutch-full-kit
I've knackered hands/wrists and stumbled on this whilst looking for future mods due to health
Thu May 09, 2019 6:45 pm quote
whip it good
Woops..should have mentioned its VBC cases so PX 200 clutch wont fit (even tho I have ground away the oil channel in the clutch cover to accommodate the banded basket (smaller diameter clutch to PX)
yo ruffstuff...I could not see any deets on the easy clutch..how do they achieve it.....physics and fulcrums on the lclutch cover lever?????
Fri May 10, 2019 12:40 am quote
I'm using a stock Cosa II in my PX/DR177. It operates perfectly and is a breeze to use. It's my city scoot, as none of my other PXs are welcome in central London any more (ULEZ). The light clutch is a real bonus in traffic, combined with the peppy pull of the DR.
2006 px125
Fri May 10, 2019 12:47 am quote
Re: whip it good
I presume it's a cable guide/ in there so you pull cable 1 and it makes cable 2 do more work, like a problem solver for a mtb mech, only guessing tho
1972 Vespa Rally 180, Piaggio LT 150
Fri May 10, 2019 6:52 am quote
Yep, it's using the mechanical advantage of a fulcrum. Move the center of effort out from the pivot point and it multiplies the force exerted.
Fri May 10, 2019 7:49 am quote
Re: whip it good
Cosa clutch fits fine in my VBC case. It's the banded SIP Sport type and case is 1976 VBC. Like Sprint V or early P series, but with old crank + bearings setup.
1974 Vespa 125 Primavera, 1980 Bajaj Chetak, 1962 Lambretta 175TV3, 2006 Yamaha Vino
Mon May 13, 2019 6:54 am quote
Crimaz makes a push rod clutch that is supposed to be great. It's available for about $60 and available from SIP. You could also go with a hydraulic clutch.
px200
Mon May 13, 2019 1:51 pm quote
I assume you have tried a dogleg lever.
Grumpy
Wed Aug 14, 2019 10:46 am quote
Do you know anyone who has installed the Crimaz push rod on a smallframe?!
Wed Aug 14, 2019 12:54 pm quote
I know someone who was going to install one on a race bike. Let me check in with him to see if that ever happened.
I have doglegs on both my bikes and while they do allow you to get more grip on the levers, they definitely don't make them any easier to pull.
Also, to the OP, do you pull the clutch in every time you shift?
Wed Aug 14, 2019 1:01 pm quote
I know they make one for a Smallframe, but I've never heard of one for the largeframe. Do you have a link?
74 50s x3 78 P200 84 Cosa PK50XL2 58 AllState 68 Sprint 80 50special '66(?) Super125
Wed Aug 14, 2019 4:14 pm quote
I think that they do for me. I know that they don't add any mechanical advantage like some of the solutions posted, but they do allow me to squeeze in a position where my hand is more fully closed and my fingers aren't reaching so I think I have more strength there. Works even better with adjustable doglegs because it's so easy to find the sweet spot.
Also check to see that you clutch cable OUTER is not longer than necessary. Too much extra outer means S curves inside the tunnel which can increase friction considerably, especially if starving for lubrication and the longer the excess, the tighter the S bends.
Wed Aug 14, 2019 6:48 pm quote
I have, but haven't tested it yet.
https://www.sip-scootershop.com/en/products/push+rod+crimaz+clutch+geared_87724000
Wed Aug 14, 2019 7:28 pm quote
Thank you Ginch, me likes!!
px244gs, cosa221LX, sprint177, gilera runner 180, triumph tiger 955
Location: vienna/austria (the other one, w/o kangaroos)
Wed Aug 14, 2019 9:22 pm quote
Exactly. And if it slips, the springs are to be replaced, withnoeigonal ones.. Always! Use the weakest possible spings to protect your big clutch bearing.
Thu Aug 15, 2019 5:53 am quote
the torque on a large frame clutch is rather low compared to motorcycles, smallframes, and lambrettas, since it rotates at crank speed and the gear reduction comes after it.
but, if it slips adding plates instead of stronger springs will address it without making it harder to pull.
2001 LML 150 2t
Thu Aug 15, 2019 1:51 pm quote
This guy is totally onto the light clutch.
Unfortunately they don't make them for vespas, but the idea is transferable if someone has the engineering skills.
https://www.clake.com.au/onelightclutch/
Thu Aug 15, 2019 3:11 pm quote
I currently have those OLC Clake clutches on three of my KTMís. Thereís definitely pros and cons to them.
You could install a Liztor hydro clutch cover, them fab up a mount for the OLC clutch master cylinder. I canít remember exactly what the piston bore is on the Clake unit though...I think it might be a 9mm?
https://www.kytronik.com/products/cnc-hydraulic-clutch-cover-for-vespa-px-cosa
Thu Aug 15, 2019 6:58 pm quote
oopsclunkthud wrote:
...but, if it slips adding plates instead of stronger springs will address it without making it harder to pull.
How can that be achieved?
WDC what are the downsides, and if using your suggestion would they be present as well?
Thu Aug 15, 2019 8:34 pm quote
the holding capability is proportional to:
pressure of the springs * Number of plates * diameter
the pulling force is only proportional to:
pressure of the springs / leverage
so if you buy a 4 plate set and don't use the heavy springs you get 33% more holding force with zero added pulling force
Did this on our yellow smallframe (that is still for sale)
2001 LML 150 2t
Thu Aug 15, 2019 9:43 pm quote
I'm quite sure 9.5mm is the piston size.
If you have any concerns with the OLC, I'd encourage you to email/call Owen (the manufacturer). He's super approachable and I'm sure he'll try and help you out.
Sun Aug 18, 2019 1:20 am quote
I guess that is only possible for a very small number of clutches though, is what I was thinking.
Phil is that the guy you were doing some work for?
2001 LML 150 2t
Sun Aug 18, 2019 2:08 am quote
Yeah it sure is. I hassled him no end to do a Vespa suitable light clutch and a Clake (that's a long shot!), but no go unfortunately. He just laughed at the prospect.
Oh well.. can't win 'em all.
Sun Aug 18, 2019 6:42 am quote
most of the 4 plate sets are thinner and can be used in a standard basket.
I've been fighting a similar pain / loss of strength in my hands the past few years. Optimizing the leverage to length of pull can also help. the large frames have more pull length than needed to disengage the clutch so more leverage is also possible. as for order of optimization:
0. fit the levers you want to run (I like the buzetti dogleg)
1. fit as many plates of the material you want to run with stock springs (plate number and material will affect the pull length)
2. figure out how much pull length you can give up and adjust the leverage to reduce the pull length.
3. don't think it would buy much but a lighter return spring could be made without too much trouble
Mon Aug 19, 2019 12:07 pm quote
My friend said that the push rod he installed on his wife's smallframe works well but still isn't super easy like a Cosa clutch.
Also, if you're someone who has trouble pulling the clutch comfortable, minimize how much you use it! I only use the clutch when I come to a stop and when I'm pulling away in 1st gear. Anything else is unnecessary.
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   vespa scooterwest scooter west Motorsport Scooters   AF1 Racing Vespa Austin
[ Time: 0.1672s ][ Queries: 25 (0.0416s) ][ Debug on ]
