PX150E
PX150E
I know, sounds like whining, but tank removal is one of those jobs I am really sick of doing on my PX150.
Can you just use 2 wrenches and remove/replace the shock from its spacer above ?
Anyone tried that yet?
TIA
Can't you access the nut from the inside of the frame just by pulling the tank up a bit (without taking it all the way out)?
PX150E
PX150E
I doubt it. The last time I changed the shock, the top shock nut inside the frame was way back there.
I am thinking that holding the spacer while unscrewing the shock (once detached from lower mount) might do it.
@chandlerman avatar
Lucky
76 Sprint V, 63 GL, 62 VBB, 05 Stella, 66 Smallstate
118 Days Since Last Explosion
Lucky
@chandlerman avatar
You could, in theory, do it without pulling the tank, but only if the shock comes out of the mount buffer without issues.
@macgerk77 avatar
Wrecked '61 VNB '65 Allstate '74 Rally 200
@macgerk77 avatar
Just pull the damn tank.
@fatbear5 avatar
1977 P200, 1980 P200
@fatbear5 avatar
I did this on my P200 last month and even with the tank out and resting on the frame, it was a damned difficult job. There is very little room to manipulate your hands, but that's probably still the best way to do it.
PX150E
PX150E
Well, I did a "dry run" this morning. The shock can be accessed on top with either 2 open ended 14mm wrenches or one wrench and a 14mm crow foot attached to 3/8" Drive extensions and ratchet. However, I am thinking that after 34 years, it would be a good idea to also replace the rubber block mount above the shock, as well; doing this will necessitate the tank removal, anyway.
My rubber block seems to be in perfect condition, but I might as well replace it, as the rubber deteriorates with age.
I will also replace the front shock and rubber spacers as well for a complete fresh suspension.
PX150E
PX150E
[ Time: 0.0342s ][ Queries: 3 (0.0085s) ][ Debug on ][ 313 ][ Thing One ]
