Rear Axle Bearing Self-Destruct
saggezza di scala
Sun May 12, 2019 9:56 pm quote
A couple of days ago I was about a few blocks from home when the rear wheel gave a tug of resistance and I suddenly began hearing a loud noise.
I pulled over and put the scoot up on the stand and tried to rotate the rear wheel by hand. It moves (it's not completely seized) but it feels rough.
I decided to ride it slowly home with the noise remaining fairly constant.
I'm assuming that one or more of the rear axle bearings self-destructed and have started to take their neighbors with them.
My shop is about 20 minutes away. It'll cost about $100 bucks to have the scoot flat-bedded to the shop.
My question is this: If the scoot can be ridden slowly, is it possible to do so in order to get it to the shop under its own power without;
a) endangering me?
and
b) doing further damage to the axle and / or surrounding area?
Don't mean to sound cheap, but I doubt anyone here would willingly light a $100 bill on fire if there was a reasonable alternative that would save it from the flame.
Sun May 12, 2019 11:35 pm quote
Ok, so first thing to do is check the rear hub oil to make sure it hasn't run very very low causing the issue. I have seen the rear hub lose oil to the point where your symptoms have surfaced. Have you checked it lately? If the oil is the cause, you may have damage in need of repair, or not! Know one can tell until you verify this. refill and try it out.
Probably more likely is a bearing is going/gone out to lunch. It sounds as if it's in the final stage of maybe breaking up.
I take it the rear caliper hasn't come loose and it's dragging the pads on the disc giving simialr symtoms??
Irrespective of what is causing the issue, I would not ride it for 20 minutes to the dealer. If something breaks, you could hit real trouble and come off the bike. Even if you don't come off the bike, you could do real damage to the hub gearbox and the housing if something shears.
If you cannot determine what the issue is, then $100 is cheap insurance to get it to the dealer. It's called protecting your investment, and you life. Good luck on this and hope it pans out ok.
Benelli TNT 125/Benelli Leoncino 500. I don't care. You can quote me.
Sun May 12, 2019 11:43 pm quote
Flat
Get it transported.
It's not worth the risk.
If it fails en route you'll be curing your decision.
Bill x
Kymco AK550
Sun May 12, 2019 11:50 pm quote
As advised above you do need to do some more investigation before any judgement can be made. Firstly make sure that the axle nut has not come loose. If you grab the wheel with both hands is there significant play when twisted out of the vertical plane? Have the brake pads disintegrated? Does the rear brake feel like its working normally without any further noises? Its also possible that some grit has been trapped in the brake calliper, this can sound quite alarming.
If a bearing has failed its more likely to be the one in the outrigger which is exposed to water and dirt rather than the transmission side which is running in axle oil. If you are sure its the outrigger bearing it would probably do no harm to ride carefully. Otherwise it doesn't sound safe given the level of uncertainty.
saggezza di scala
Mon May 13, 2019 12:06 am quote
Thanks all. Called the truck.
Don't want to be penny wise and pound foolish.
Mon May 13, 2019 12:10 am quote
Click
Good decision.
Well done that man.
Bill x
Sponsor
Granturismo 218
Mon May 13, 2019 4:02 am quote
Did you recently have a rear tire changed?
saggezza di scala
Tue May 14, 2019 1:38 am quote
No. Interesting question. Why do you ask?
saggezza di scala
Tue May 14, 2019 1:41 am quote
So, as suspected, the rear axle bearings looked like the morning after an epic frat party when my mechanic got the scoot up on the lift.
No damage to the axle or surrounding bits.
All sorted.
Tue May 14, 2019 1:46 am quote
Look
Pictures.
Bill x
2006 Vespa GT (Rocket): 2005 Vespa GT (Razzo): 2006 Vespa GT (Crash): 2007 Vespa GT (Vanessa): 2009 Yamaha Zuma 125 (Zoom): 2018 Yamaha Xmax (Max),
As for towing costs, I just renewed my AMA membership.
The membership includes free towing for up to 30 miles.
It costs $145 for three years.
In the first three years I have had it, I had scooters towed at least five times and my Miata once.
These tows would have cost at least $100 each, so quite a savings.
Do you have a similar club in Israel?
Bill
Tue May 14, 2019 3:06 am quote
In the first three years I have has it, I had scooters towed at least five times and my Miata once.
So you have a similar club in Israel?
Bill
Progressive towing, up to $600 per incident and it only $10 a year. If I am reading my policy right
Tue May 14, 2019 3:32 am quote
Yes, that is a good one, but I have State Farm. They don't offer the same.
Tue May 14, 2019 5:04 am quote
Re: Look
Bill Dog wrote:
Pictures.
Bill x
Pictures of a frat party could be very interesting indeed.
The aftermath, not so much.
bodgemaster
1963 GL, 1976 Super (x 2), 1974 Primavera (x 2), 2006 Fly 150
Tue May 14, 2019 6:24 am quote
saggezza di scala
Tue May 14, 2019 11:08 pm quote
Re: Look
Bill Dog wrote:
Pictures.
Bill x
I wasn't there. My mechanic's description.
2006 250ie
Wed May 15, 2019 6:06 am quote
How many km did you have on the bearing?
saggezza di scala
Thu May 16, 2019 12:52 am quote
145,000 km
2016 Vespa GTS 300 i.e. ABS, 2010 Vespa GTS 300 ie Super (sold) & 2003 Honda Shadow VT750 ACE (sold) & 2006 Vespa LX150 (sold)
Thu May 16, 2019 3:09 am quote
Treppenwitz wrote:
145,000 km
Here’s wishing you 145k happy carefree kms on the new bearing
Thu May 16, 2019 3:41 pm quote
All sorted.
Great news...well done for posting about it.
Your Rally Here   vespa scooterwest scooter west Motorsport Scooters   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1442s ][ Queries: 25 (0.0345s) ][ Debug on ]
