MP3 500 overheating at motorway speeds
2014 MP3500
Thu May 16, 2019 12:45 pm quote
Hi all. I have a weird overheating issue with my MP3 500. For normal riding around town and under 65mph temp is fine, gauge is in the middle (our even below) and will stay there all day. However, if I ride at over 65mph for more than a few mins the temp begins to climb and heads to red zone. If I slow down to about 5k rpm it settles back down to middle of the gauge.
I've drained the coolant and bled the system - based on volume of coolant I put in I think there's very little if any air in there. I've watched the level and its not leaking or losing coolant either. I checked the impeller on the water pump and this also seems to be fine - I had thought it may be worn and was cavitating at high speed. I read somewhere that someone suggested it could be the thermostat allow the coolant to flow to fast around the engine at high speed and not allow enough time to properly cool.
Any thoughts? Weird problem and is annoying to be stuck at <65mph
Thu May 16, 2019 1:04 pm quote
is the fan kicking on?
I suspect an air pocket in the system
2014 MP3500
Thu May 16, 2019 1:08 pm quote
Yes, fan kicks in when it should. I agree it sounds like an air pocket but I'm getting liquid only out of the bleed plug. V. confusing.
Thu May 16, 2019 1:11 pm quote
Thermostat not fully opening?
2008 fuoco
Thu May 16, 2019 1:15 pm quote
If the thermostat was stuck open then the coolant temp would be showing low not high. I would investigate the thermostat as MS says it may not be operating as it should.
Kymco AK550
Thu May 16, 2019 11:46 pm quote
Yes this is a symptom of the thermostat not opening. Feel the temperature of the radiator and/or the radiator feed and return pipes and you might find that the radiator is not hot, whereas it should be very hot if the gauge has gone up. Did you bleed the system at the cylinder head? If there is an airlock around the thermostat it will not open properly.
2014 MP3500
Fri May 17, 2019 2:51 pm quote
Thanks all, very helpful.
2019 MP3 hpe 500 sport Advanced " Missy "
Thu May 23, 2019 1:36 pm quote
I would suggest that you have your Freezeplugs checked also. I had to have a Major Oberhaus Matilda's Motor because of a defective Freezeplug.
Mon May 27, 2019 3:52 am quote
What was defect?
Did it leak?
How long between coolant changes?
2016 MP3/500 Sport ABS, 2009 MP3/250, 2012 GTS Super 300ie
Thu May 30, 2019 5:56 am quote
That's what I was thinking...
Keith,
Marietta, GA
Thu May 30, 2019 6:53 am quote
Keith,
Marietta, GA
and me too......
Check the rad when the block is hot, if not hot bleed system or change thermostat.
2014 MP3500
Mon Jun 10, 2019 12:55 am quote
Found the problem
Turns out it was a split in the impeller so at higher speeds it was slipping on the shaft. Of course this super cheap fix was not discovered before I'd spent the money on having the thermostat checked (and all the time consuming gubbins removed to get at it)
2018 GTS300 Super Sport - Donatello Vespace
Mon Jun 10, 2019 5:29 am quote
Very nice tour. I was not aware of Bitza's passing - so sad! I had been "away" from MV for almost a year due to some unexpected "things" in our lives. Thank you for dedicating this to him.
Rallies Europe 2016   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.1263s ][ Queries: 23 (0.0289s) ][ Debug on ]
