ASR warning light stays lit after diagnostics flashes
Piaggio MP3 500
Fri May 31, 2019 2:03 am quote
Hi! New forum member here with an MP3 500 -16.
When I started it up for the first time this season I noticed that the ASR warning light stayed on. At first it flashed together with the ABS light in their diagnostics phase. But when the ABS light turned off, the ASR stayed lit.
I have checked the tire pressure and it's like the manual says it should be, 2.0 in the front and 2.4 in the back. I tried to do the ASR recalibration, but it seems like it's not possible to enter the calibration state when the warning is lit.
Any ideas?
One other thing that may or may not be related is that the battery is possibly bad. I have recharged it so it should be fully charged, however the voltage shows ~10V once I have attached it to the bike. The charger claims that it's fully charged, but evidently it's not. The bike starts just barely. I guess this could mean that either the battery or the charger is faulty. Once the bike is started it shows ~14.5V, so the on board charging system seems ok.
Could a low voltage cause problems with the ASR? I'm thinking that it shouldn't be related since the ABS is not affected, but I'm far from an expert.
2016 MP3/500 Sport ABS, 2009 MP3/250, 2012 GTS Super 300ie
Fri May 31, 2019 6:05 am quote
Question: Did the lights change any after riding the bike?
Keith,
Marietta, GA
Piaggio MP3 500
Fri May 31, 2019 6:54 am quote
No change. It stayed lit.
I called a shop and they said it could be sensitive to battery problems, so I'll get a better charger and test the battery some more.
2016 MP3 500 Sport ABS
Sat Jun 01, 2019 8:36 am quote
Sounds like a battery with a bad cell.
2016 MP3 500cc Sport ABS
Sun Jun 02, 2019 9:50 am quote
If the ASR is Off the light will stay ON no?
Are you sure it's not because you switched off the ASR that the light stay ON?
Sun Jun 02, 2019 11:21 am quote
"One other thing that may or may not be related is that the battery is possibly bad. I have recharged it so it should be fully charged, however the voltage shows ~10V once I have attached it to the bike. The charger claims that it's fully charged, but evidently it's not. The bike starts just barely. I guess this could mean that either the battery or the charger is faulty. Once the bike is started it shows ~14.5V, so the on board charging system seems ok."
You need a battery. 10 volts after charging, it is bad.
2019 MP3 500 HPE Business
Sun Jun 02, 2019 9:16 pm quote
+ 1
Piaggio MP3 500
Tue Jun 04, 2019 12:16 am quote
+ 1
Unfortunately yes, I'm sure I didn't switch it off. The ASR button does nothing when pressed. Also, the ASR is supposed to turn on everytime when the engine is started. You have to explicitly turn it off everytime if you want it off. At least that's what I understand from reading the owners manual.
Anyway, my current bet is that the battery was too discharged, and that the cheap battery charger I used couldn't handle that. I have ordered a better one (CTEK MXS 5.0 Test & Charge) which might be able to fix it. I'll hopefully get it this week. And if that doesn't work I guess it's time for a new battery.
Tue Jun 04, 2019 2:23 am quote
It's not your battery charger, it is your battery.
It would charge with a 0.25 amp charger, it would just take longer.
It is as charged as it is going to get.
Piaggio MP3 500
Mon Jun 10, 2019 3:28 am quote
I got the new charger and charged the battery with it. Checking with a voltmeter after charging shows ~12.5V. That's ok right?
However, after putting the battery back in the bike, when I turn on the ignition, the bike shows ~9.6V
Would you still say it's the battery that's faulty, or would it be something wrong in the bike?
Mon Jun 10, 2019 4:22 am quote
Battery
Mon Jun 10, 2019 7:08 am quote
Absolutely, definitely, conclusively the battery. Just get a new one - and don't forget to fully charge it before first use!
Piaggio MP3 500
Thu Jun 13, 2019 2:52 am quote
WEB-Tech wrote:
Battery
Well, imagine that, you were right, who would have thought
I bought a new battery and it works fine now. It starts fine, and the ASR light turns off like it should!
Still was worth a try with the new charger though, since I needed one anyway. Can't keep borrowing my friends charger forever
Thanks!
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   vespa scooterwest scooter west Motorsport Scooters   Scooter Parts Company
[ Time: 0.1918s ][ Queries: 23 (0.0305s) ][ Debug on ]
